7 Export/Import Schedule Configuration
This chapter explains the export/import schedule configuration feature of POM.
Overview
POM provides a feature, in the user interface, to export and import schedule configuration data such as data retention limits, throttle limits, enable/disable flags, schedule times, notifications configuration, and so on.
This feature can be used in two ways:
  1. Data exported on a specific environment can be imported back on a different environment without any modifications. This is a typical use case where the batch schedule on a certain environment, such as Stage, is set up and fine-tuned according to a customer's requirements. This includes specifying which jobs should or shouldn't run. It also includes specifying the times certain cycles or flows will start. It also includes specifying the e-mail addresses that will receive certain notifications and how long to keep those notification in the system before purging them.
    Once the schedule is configured and fine-tuned (on Stage, for example) the export/import feature can be used to export the configurations from Stage and import them back into production.
    The user has the option to export to a spreadsheet or a JSON file. In this first use case, it is recommended the user exports to a JSON file then imports it back into the other environment.
  2. Data can be altered in the exported spreadsheet then imported back into the same environment. This is useful at provisioning time where an environment is first set up with the default batch schedule configuration. A user would then export the default configuration, then modify that configuration on the spreadsheet to conform to the customer's needs. The spreadsheet is then imported back into the same environment, applying the desired configurations.
    When importing the spreadsheet on the Batch Administration screen, the user will have the option of importing job-related configuration or scheduler-related configuration (run times) or both. Refer to the "Batch Administration" section in the POM User Guide for more details.
This chapter describes each tab in the exported spreadsheet, along with the data on each sheet. It also indicates which fields can be modified.
Schedule Info Tab
This is an informational only tab. No fields are modifiable on it.
Table 7-1 Schedule Info
Field Description Modifiable?
Name
Schedule or application name.
No
Version
Schedule version.
No
Installation Date
Date the schedule was uploaded into POM.
No
Customer Name
This is used on notifications to identify which customer a notification is for.
No
Environment Name
This is used on notifications to identify which customer's environment a notification is for.
No
Schedule Configuration Tab
This tab contains schedule level settings.
Table 7-2 Schedule Configuration
First Run Business Date
Date when batch was run for the first time. See subsection "Business Date Explained" in the "System Configuration" section of the POM User Guide.
No
Data Retention Days
Number of days historic data is to be retained in POM.
Yes - Recommended value is 30 days.
Long Run Average Multiplier
Number which is multiplied by a job's average run time or Threshold Runtime (if provided) to determine the threshold which, when exceeded, the job is deemed long running.
Yes - Usually a number between one and three.
External Dependencies
Indicates whether POM will respect external dependencies or not. They are usually dependencies on customers' internal processes.
Yes - Valid values are Y or N.
Inter-schedule Dependencies
Indicates whether POM will respect external dependencies or not. Those are dependencies on other schedules.
Callback mode
This is also known as External Status Update Mode. Depending on the value, the customer's system is notified of success or failure of any job in the entire schedule. The value set here is overridden by this same setting for any individual job defined on the other job-specific tabs.
Yes - Valid values are ALL, FAILED or NONE.
When value is NONE, no callback is made.
When value is ALL, callback is made on either success or failure.
When value is FAILED, callback is made only on failure
Throttling Tab
At this time, this tab should only be used to set throttle limits at the application level. Throttling is a technique used to limit the number of jobs that can run concurrently for a specific application. Throttling limits are set so a server's resources are not overwhelmed by too many concurrently running jobs.
Previously, throttle limits could be set at the application level and/or at the module level. Now they can only be set at the application level.
Also note that this tab was intended to provide the capability to enable/disable whole applications or modules. This is not functioning at this time. In order to achieve this objective, filter on application on the Nightly Jobs Configuration, Recurring Jobs Configuration or Adhoc Jobs Configuration, then change all enabled flags to 'Y' or 'N' as desired. For enabling/disabling whole modules, this has to be done on the Batch Administration screen at this time.
(Continued)
Table 7-3 Throttling Configuration
Field Description Modifiable? - Possible values
Application
Application code.
No
Module
Module name.
No
Job Admin
Job Admin is the component usually running on the same server as the application and which executes that application's batch jobs.
No
Throttle Limit
The max number of jobs that can run concurrently for the specified application.
Yes - A number that is greater than zero.
Enabled
This flag currently does not enable or disable jobs belonging to an application/module. See the second note at the top of this section for more information.
Nightly Jobs Configuration Tab
This tab contains all Nightly cycle's jobs along with their configuration.
Table 7-4 Nightly Jobs Configuration
Job
Job name.
No
Process
Process name to which the job belongs; a process can contain multiple jobs.
No
Cycle
This is a fixed value for this tab of 'Nightly'.
No
Application
Application name to which this process-job belongs.
No
Initial Parameter
The initial parameter this job was set up with when the base schedule was first loaded into POM.
Yes - Can contain blank or any space-separated list of parameters.
Parameter Change
Flag indicating whether the parameter can be changed after the initial load. If it can, then the new value must be loaded in the next field: Active Parameter.
Active Parameter
Parameter which overrides the Initial Parameter when Parameter Change is 'Y'.
Skip on error
Flag indicating whether this job can be skipped when it fails.
Callback mode
This is also known as External Status Update Mode. Depending on the value, the customer's system is notified of success or failure of this specific job by calling a predefined customer endpoint. The value set here overrides that of this same setting on the Schedule Configuration tab.
Day of week
Contains the day(s) of the week on which this specific Job will run. POM automatically skips these Jobs on remaining days.
If this field is left blank, the job will run on every day of the week.
Yes - Valid values are blank or any number of comma separated days of the week (for example: SUNDAY,MONDAY,TUESDAY, WEDNESDAY,THURSDAY, FRIDAY,SATURDAY)
Threshold Runtime
Estimated runtime in seconds for this specific job. This is an optional field which, when entered, will be used to multiply by the Long Run Average Multiplier defined on the Schedule Configuration tab. When the resulting number is exceeded, the job is deemed long running. If this field is blank, then the job's average run time is used instead to multiply by the Long Run Average Multiplier.
Yes - Valid values are blank or an integer number of seconds.
Enabled
Flag indicating if this job is enabled or disabled
Notify Job Start
Flag indicating if a notification is to be sent at start of this job.
Notify Job Completion
Flag indicating if a notification is to be sent at successful completion of this job.
Recurring Jobs Configuration Tab
This tab contains the list of Recurring cycle/Process/Job along with their configuration.
Table 7-5 Recurring Jobs Configuration
Job
Job Name
No
Process
No
Cycle
Name of the hourly/recurring cycle this job belongs to.
No
Application
No
Initial Parameter
Parameter Change
Active Parameter
Yes - Can contain blank or any space separated list of parameters.
Skip on error
Callback mode
This is also known as External Status Update Mode. Depending on the value, customer's system is notified of success or failure of this specific job by calling a predefined customer endpoint. The value set here overrides that of this same setting on the Schedule Configuration tab.
Day of week
Contains the day(s) of the week on which this specific Job will run. POM automatically skips these Jobs on the remaining days.
Yes - Valid values are blank or any number of comma-separated days of the week (for example: SUNDAY,MONDAY,TUESDAY, WEDNESDAY,THURSDAY, FRIDAY,SATURDAY)
Threshold Runtime
Estimated runtime in seconds for this specific job. This is an optional field which, when entered, will be used to multiply by the Long Run Average Multiplier defined on the Schedule Configuration tab. When the resulting number is exceeded, the job is deemed long running. If this field is blank, then the job's calculated average run time is used instead to multiply by the Long Run Average Multiplier.
Enabled
Flag indicating whether this job is enabled or disabled.
Notify Job Start
Flows Configuration Tab
This tab contains a flow/cycle matrix. It contains a row for each flow and all recurring cycles as columns. An intersection of 'Y' means the given flow is defined to run as part of the given recurring cycle. It is recommended that all recurring cycles are enabled but not necessarily scheduled for running. See the Scheduling Flows Tab for further clarification.
Table 7-6 Flows Configuration
Flow
Flow name.
No
Recurring cycle 1
A 'Y' or 'N' value indicating whether the given flow is run as part of recurring cycle 1.
A value of N does not disable jobs belonging to the flow/cycle intersection. Those jobs need to be manually disabled on the Batch Administration screen.
Recurring cycle 2
A 'Y' or 'N' value indicating whether the given flow is run as part of recurring cycle 2.
Recurring cycle n
A 'Y' or 'N' value indicating whether the given flow is run as part of recurring cycle n.
Adhoc Jobs Configuration Tab
This tab contains the list of ad hoc jobs (also known as standalone) along with their configuration.
Table 7-7 Adhoc Jobs Configuration
Job
Job name.
No
Process
No
Cycle
This is a fixed value for this tab of 'Adhoc'.
No
Application
No
Initial Parameter
Parameter Change
Active Parameter
Skip on error
Callback mode
This is also known as External Status Update Mode. Depending on the value, the customer's system is notified of the success or failure of this specific job by calling a predefined customer endpoint. The value set here overrides that of this same setting on the Schedule Configuration tab.
Day of week
Threshold Runtime
Enabled
Notify Job Start
Job Dependencies Tab
This tab contains the definitions of all intra-schedule dependencies (or job dependencies within the same schedule) for all cycles (Nightly, Recurring and Adhoc). External, inter-schedule dependencies and execution links are defined on the Job External Associations tab.
Only the Enabled flag can be changed on this tab. Caution should be exercised when disabling a dependency, as in certain situations this can cause a job to run before data is processed by the predecessor job. This can therefore cause data corruption.
Table 7-8 Adhoc Jobs Configuration
Job
Job name.
No
Process
Process name to which the job belongs.
No
Cycle
Nightly, Adhoc or specific recurring/hourly cycle.
No
Predecessor Process
Process name to which the predecessor job belongs.
No
Predecessor Job
Job which must complete before the job defined on the current row can run.
No
Enabled
Flag indicating whether this dependency is enabled or disabled.
Job External Associations Tab
This tab contains the definitions of External dependencies, inter-schedule dependencies and execution links, so all dependencies other than the intra-schedule dependencies described in the previous section.
New external associations can be added in this tab.
External dependencies are usually those defined for customer processes. These are associated with a POM endpoint that the customer calls to satisfy the dependency.
Inter-schedule dependencies are those associated with another schedule. For instance, a Retail Insight job can be made to wait for a Merchandising job to complete.
An Execution link is a special dependency that sets up an application's schedule to be invoked based on a completion of a job in another application’s schedule. For instance, the Retail Insight schedule can be set up to be invoked when job A completes in the Merchandising schedule.
Table 7-9 Job External Associations
Job
Job name.
Yes - Needs to be a valid job name already defined on the nightly schedule.
Process
Yes - Needs to be a valid process name already defined in the nightly schedule.
Cycle
Cycle name.
Yes - This can only be Nightly.
Association Type
Type of dependency.
Yes - Valid values are Internal for Inter-Schedule, External and EXEC_LINK
External Schedule
Name of the schedule containing the inter-schedule dependency or execution link.
Yes - This must be an existing valid schedule defined in the same instance of POM. This is only required for inter-schedule dependencies and execution links.
External Job
Name of external job.
Yes - In the case of an external dependency, this is the name that will be included in the payload of an endpoint called by the external system, such as the customer's.
In the case of inter-schedule dependencies and execution links, this is a valid job name defined in the dependent schedule.
External Process
Process name to which the external job belongs.
Yes - This is required for inter-schedule dependencies and execution links. It's the process name associated with the external job.
Enabled
This tab and the next contain configurations for scheduling flows or processes to run at specified times.
This Scheduling Flows tab contains the definitions of scheduled run times for the Nightly and recurring flows.
It simply contains one row for the Nightly flow stating the time when the Nightly processes will start every day.
The rest of the tab contains rows for each recurring flow, with columns for each of the hourly cycles making up the flow. For each cell at the intersection of Flow and hourly cycle, the time is entered for when the cycle is to start running. At present, there is a maximum of 24 hourly cycles that can be defined which, when spaced equally, would run one hour apart. Times are optional, so a blank cell indicates that the cycle will not be scheduled to run.
Although there is no validation that cross-references the presence of a time in a cell with the enabling of the cycle on the Flows Configuration tab, ideally these would match up. This means that, if you enter a time for running an hourly cycle, the same intersection on the Flows Configuration tab should be 'Y'. However, it is conceivable to enable the cycle on the Flows Configuration tab but not schedule it, leaving the option open to schedule it as needed. In fact, this is the recommended practice: Enable all hourly cycles and only schedule a few as needed, but have the option to run more to catch up when necessary.
The timezone region ID entered in cell B is used for all times entered for all subsequent cycles on a given row. It is possible to specify a different timezone for select time cells (for example, 5:00 America/Chicago).
If the timezone region ID is null in the database, UTC is exported as the default into cell B of this tab.
Table 7-10 Scheduling Flows
Flow
Flow name.
No
Timezone Region ID
Timezone corresponding to the time entered in the subsequent cell(s). Timezone region ID is required, rather than a UTC offset (such as "UTC-06:00"). This is to accommodate Daylight Saving Time.
Yes - Valid timezone region IDs such as US/Eastern can be found as TZ database name at https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
Nightly
Only fill this cell if Flow is Nightly. Enter the time for starting the Nightly cycle.
Yes - Enter a valid military time format such as 6:00 (6am) or 22:00 (10pm).
Recurring cycle 1
Enter a time in this cell to schedule recurring cycle 1 to run at that time. Leave blank to forego scheduling recurring cycle 1. It is possible to not schedule the cycle by default but elect to run it manually if needed.
Yes - Enter a valid military time format such as 6:00 (6am) or 22:00 (10pm). Conflict with the Nightly batch flow should be avoided as POM will skip running a recurring cycle if its start time is elapsed while Nightly is running.
Recurring cycle 2
Enter a time in this cell to schedule recurring cycle 2 for running at that time. Leave blank to forego scheduling recurring cycle 2. It is possible to not schedule the cycle by default but elect to run it manually if needed.
Recurring cycle n
Enter a time in this cell to schedule recurring cycle 1n for running at that time. Leave blank to forego scheduling recurring cycle n. It is possible to not schedule the cycle by default but elect to run it manually if needed.
Scheduling Adhoc Tab
This tab contains the definitions of scheduled run times for the ad hoc processes.
Table 7-11 Scheduling Adhoc
Process
Adhoc process name.
No
Description
Description of reason for running this Adhoc process at the specified time.
Yes - Optionally describe the purpose for scheduling the Adhoc process at the specified time
Frequency
Frequency in minutes at which this Adhoc process is to be run.
Yes - Valid values are Daily meaning run this process once at the specified time, or EVERY:x, where x is number of minutes. For example EVERY:120 means run this process every two hours.
Limit Occurrences
Relevant only when frequency of EVERY:x is used. If a Limit Occurrences value is entered, the process will run a maximum of times equal to the specified limit.
Yes - A positive integer. For example: Frequency of EVERY:120 with a Limit Occurrences of 4 means the process will run every two hours a maximum of four times
Prevent start during nightly
A flag which, when set to Y, indicates that this process is not to be started when the Nightly process is running. If the Scheduler tries to start a run while Nightly is running, the execution's status is set to Error with an Info message of "Nightly started running so can't run the process."
Schedule Time
Entering a time in this field causes the process to be scheduled at that time in case of a DAILY frequency or to start the first run at that time in case of an EVERY:x frequency.
Leaving this field blank causes the process to run immediately or the first run to start immediately when the scheduler day starts.
If a specific time is entered in this field but the scheduler day starts after that time, the process will be scheduled for the next day at that time.
Enabled
Flag indicating if this process is to be scheduled.
Timezone Region ID
Timezone corresponding to the time entered in the subsequent cell(s). Timezone region ID is required rather than a UTC offset such as UTC-06:00. This is to accommodate Daylight Saving Time.
Notification Tab
This tab contains all POM-defined notification types and associated e-mail addresses and retention periods. For a list of notification types, refer to Notifications.
Table 7-12 Notifications Configuration
Notification Type
Type of notification. There are several events in POM for which notifications are generated. An example of a notification type is: NightlyStart.
No
Email Subscription
Email address to which notifications of this type will be sent.
Yes - Valid values are blank or correctly formed email addresses.
Retention Period
Period in days notifications generated for this type are to be retained in the system before purging..
Yes - Valid values are blank or an integer number of days.
