10 Invoking POM Services Using OAuth
This chapter details the steps to invoke POM ReST services using the OAuth protocol. Using the OAuth protocol is a two-step process:
Request an access token from an authentication provider: IDCS or OCI IAM.
Provide the access token as an authorization header when invoking a service.
Prerequisite
rgbu:pom:services-customer-administrator-<ENV_ID>where <ENV_ID> represents the unique environment identifier such as PRD1, STG1, DEV1 and so on.
rgbu:pom:services-customer-administrator-DEV1For more information about creating the OAuth client, refer to the "Creating IDCS OAuth 2.0 Client Apps" chapter in the Retail Home Administration Guide.
Requesting the Access Token
To generate a token from IDCS, the following information is needed:
IDCS URL
Client Id and Client Secret
OAuth Scope
The curl command below invokes an IDCS service to generate an access token:
curl -I -H 'Authorization: Basic <base64Encoded OAuth_Clientid:Secret>' -H 'Content-Type: application/x-www-form-urlencoded;charset=UTF-8' --request POST <IDCS_URL>/oauth2/v1/token -d 'grant_type=client_credentials&scope=rgbu:pom:services-customer-administrator-<ENV_ID>'This is a standard ReST call, with the following specifics:
<IDCS URL> is the IDCS URL of this instance.
<base64Encoded OAuth_Clientid:Secret> is the Base64-encoded OAuth Client Id and Client Secret provided as a Basic Authentication header.
Specify the body as:
The response to this call will be in this format:
{ "access_token": "<TOKEN>", "token_type": "Bearer", "expires_in": 3600 }
Invoking the POM Service
To invoke the POM ReST service, you must add an authorization header as Bearer <token>, that is:
The word Bearer
A space
A valid token obtained as described in Requesting the Access Token
For example, the POM nightly cycle start request would look something like the following:
curl -i -H 'Authorization: Bearer <OAuth Token>' -H 'Content-Type: application/json' --request POST 'http://<pom-server-host>/ProcessServices/services/private/executionEngine/schedules/<Schedule_Name>/execution?skipVersion' -d '{ "cycleName" : "Nightly", "flowName" : "Nightly"}'
