3 Noteworthy Resolved Issues
This following table highlights specific key fixes that are included in this release. In some cases, only a percentage of the overall fixed defects are listed.
Affected Component | Defect Number | Summary |
Logging |
34793681 |
Request to add the feature of auditing the schedule change in POM. POM added logging capabilities for most actions performed in the UI and through APIs. See Added Logging Capability in the Feature Summary chapter above for more detail. |
Installer |
34535652 |
Fixed issue where a re-attempt of a failed upgrade
resulted in multiple entries of the |
Notifications |
N/A |
Fixed an issue where a Job fails in POM when a notification's email recipient list string is longer than 400 characters. |
