Configuration
A Scheduler Task can be configured at the following frequencies.
| Frequency | Description |
DAILY |
Run daily at the specified time |
WEEKLY |
Run every <day of a week> at the specified time. The business date of the Schedule is used here, to determine the day of the week. |
ONCE |
Run once at a specified date and time. The business date of the Schedule is used here, to determine the date at which the task is being run. |
MONTHLY |
Run on a particular day of each month at a specified time. For example, on the 15th of each month at 10pm The business date of the Schedule is used here, to determine the day of the month. |
MONTHLY_START |
Runs at the beginning of every month. The business date of the Schedule is used here, to determine if it is the start of the month. |
MONTHLY_END |
Runs at the end of every month. The business date of the Schedule is used here, to determine if it is the end of the month |
Within each of the frequencies above, the following recurrences are supported.
| Recurrence | Description |
SINGLE |
Will run just once at the time defined on the frequency |
MULTIPLE |
Will run multiple times at regular intervals starting at the time defined on the frequency |
