3 Noteworthy Resolved Issues
This following table highlights specific key fixes that are included in this release. In some cases, only a percentage of the overall fixed defects are listed.
| Affected Component | Defect Number | Description |
Notifications |
35338936 |
Business date missing in long-running notification from last job of nightly cycle |
Batch Execution |
35421306 |
Job fails ORA-00054: resource busy on |
Batch Execution |
35447166 |
RPASCE POM agent error when executing RDF daily job |
Scheduler |
35238940 35311194 |
POM should ensure that schedule execution is on the next day (after the last execution) POM bug: allows running more than one scheduled nightly batch per calendar day The fix entails preventing more than one nightly from running on the same calendar day. This default
behavior can be altered by setting the system option |
User Interface |
35450278 |
POM screen refresh issues: This issue was more specific to the Batch Monitoring Standalone screen. The screen has now been redesigned to alleviate the refresh issue. |
Roles |
35341074 |
A user with production roles stopped working after an upgrade. The workaround was to give the user pre-prod roles. The fix is to permanently restore the production roles. |
