Introduction
Before this feature was implemented in POM, Batch Schedules were immutable, in the sense that they could only be modified by changing the spreadsheet. These Schedules could only be customized with External Dependencies, Schedule Links or Inter-schedule dependencies, and so on. However, there was no way to add a new Batch Process or Batch Job through the POM UI. Additionally, the dependencies between Jobs that are stitched into the Batch Schedule as specified within the Spreadsheet, could not be modified at runtime.
These limitations are quite restrictive, and in order to overcome them, Custom Batch Entities (CBEs) were introduced in POM. A Batch Entity (Flow or Process or Job) that is added to a Batch Schedule, using either the Custom APIs or the POM UI, is a Custom Batch Entity (CBE). These CBEs are distinctly separate from the Batch Entities that are seeded as part of the Batch Schedule spreadsheet. All CBEs added are associated with the Standalone cycle by default.
In POM, the execution APIs support the execution of either a Batch Process or a Batch Flow. These entities are therefore deemed invoke-able. The Batch Monitoring screen for the standalone cycle provides an invoke-able centered view, rather than a Job centric view seen on the Nightly and Recurring cycles. The Custom APIs and the UI, provide controls for the creation of custom invoke-ables, while custom Jobs can be added as part of these custom invoke-ables.
Type | Features |
Custom Batch Job |
Custom Batch Process |
Custom Batch Flow |
All modifications to CBEs are audited, and will show as a corresponding audit event on the Audit Events screen.
Today, all Custom Entities execute as standalone invoke-ables. They cannot be linked with or have a dependency on a Job in the Nightly Cycle. This capability will be added in a future release.
