Notifications
The Scheduler generates the following Notifications, at different points of execution.
Notification Type Description
SchedulerTaskFailed
This signals that something went wrong, when executing the Scheduler Task Instance.
SchedulerTaskSkipped
On failure to schedule an ENABLED task.
SchedulerTaskDelayed
Occurs when we try to run the task manually from the Batch Monitoring screen, and the time has passed.
SchedulerTaskOccurenceSkipped
Occurs when the Scheduler has to adjust the invocations for a task instance, as the occurrence time for some invocations has passed.
SingleNightlyPerDayValidation
This is created, when the Scheduler applies the One Nightly per Day rule to the Nightly task and bumps it by a day.
