3 Noteworthy Resolved Issues
This following table highlights specific key fixes that are included in this release. In some cases, only a percentage of the overall fixed defects are listed.
| Affected Component | Defect Number | Description |
| Batch Administration |
33921235 & 31439468 |
Jobs table in Batch Administration screen is enhanced with multi-row selection capability. See the Batch Administration Job Multi-Update Capability entry above in the Noteworthy Enhancements. |
| Health Check | 35707712 | POM Callback failing with “Unsupported Media Type” error is fixed. |
