Notifications
The Scheduler generates the following Notifications, at different points of execution.
| Notification Type | Description |
SchedulerTaskFailed |
This signals that something went wrong, when executing the Scheduler Task Instance. |
SchedulerTaskSkipped |
On failure to schedule an |
| SchedulerTaskCancelled |
This is created when the scheduler is |
SchedulerTaskDelayed |
Occurs when we try to run the task manually from the Batch Monitoring screen, and the time has passed. |
SchedulerTaskOccurenceSkipped |
Occurs when the Scheduler has to adjust the invocations for a task instance, as the occurrence time for some invocations has passed. |
SingleNightlyPerDayValidation |
This is created, when the Scheduler applies the One Nightly per Day rule to the Nightly task and bumps it by a day. |
