3 Noteworthy Resolved Issues
This following table highlights specific key fixes that are included in this release. In some cases, only a percentage of the overall fixed defects are listed.
Affected Component Defect Number Summary
Batch Administration
36194372
The issue with the filter for the Enabled column on the Batch Administration screen is fixed. The filter now allows the user to select All, Yes or No to filter Jobs based on their enabled/disabled status.
Batch Monitoring
36194372
The positioning of the horizontal scrollbar on the Batch Monitoring table now adjusts based on the number of rows in the table. Furthermore, the horizontal scrollbar can be accessed, regardless of the number of jobs, by scrolling vertically to the bottom of the table.
Nightly Batch - Scheduler Day
35943394 36121889 36061449
Under some circumstances, at the completion of the Nightly schedule, there was a small window of time during the rollover to the next day where an Adhoc or Recurring job can sneak in and run without a record of having run. This is fixed in this release to ensure that no more execution requests are allowed on the current scheduler day after the completion of the last Nightly job.
External Dependency
36152556
Any extra spaces added at the end of the COMPLETED part of the URL for releasing an external dependency are now trimmed to avoid failure when called from Curl or Postman.
Schedule Upgrade
36295693
User was getting an error: “Cannot start a new upgrade of schedule null because an upgrade is already in progress.”
This was due to POM not showing and not ignoring previous failed schedule upgrades on the Schedule Maintenance screen.
A fix was added to show previous failed upgrades row and not consider them as active upgrades.
