Add Items
In the Items Detail section, it is possible to add or remove items:
  • To add items for the price event, click the + icon.
  • To remove items from the price event, select the record to be deleted and click the – icon.
This image shows the Add Items dialog box.
To add items:
  1. In the Details table, click the + icon.
  2. In the Add Items dialog box. enter the following information. Add items by choosing between the available values:
    • Item - choose between the available options to add items by:
      • Item - select the list of MFCS items for the price event.
      • Item description - select the list of MFCS items for the price event based on description.
      • SKU - select the list of MFCS items for the price event.
      • Style - select the list of MFCS items for the price event.
      • Barcode - select the list of MFCS items for the price event based on barcode.
      • VPN - select the list of MFCS items for the price event based on VPN.
    • CSV Upload - choose the file.
  3. Click Add to add the selected items to the table with the list of items to be added to the price event. If required, it is possible to remove items before submitting them directly on the table.
  4. Click Submit to add the selected list of items to the price event.
  5. Click Close to close the dialog box without saving the items.
If Pricing Control is enabled, users will only be able to submit items based on their user type. This functionality is only available if Pricing Control is enabled on MFCS and RPCS Release 24.0.101.0+.
