Configure Users
Four user types can be configured in the Supply Chain Hub:
- Retail Admin:
- Has permission to access the Profile screen and configure suppliers and users.
- Retail User:
- Can be assigned to use one or more modules.
- Can be assigned to one or more suppliers and one or more departments.
- If no suppliers and/or departments are directly associated, the user will have access to all suppliers/departments.
- Supplier Admin:
- Needs to be assigned to at least one supplier.
- Can change supplier user permissions.
- Supplier User:
- Will only have access related to the associated suppliers.
- Will only have access to the assigned modules.
The creation of users, their allocation to suppliers, and activation/deactivation is managed in the Supplier Evaluation module, using the Users and Supplier Users tasks. The Supplier Evaluation user account is then automatically synchronized with the Supply Chain Hub user account.
- Configure retailer administrator access from Supplier Evaluation
Before configuring the user, ensure that Supply Chain Hub is enabled in the environment and available. Merchandising integration must be enabled, with an integration interval greater than zero and an integration URI configured.
- In Supplier Evaluation, select Admin → Roles & Permissions → User Roles. Open Oracle Authorized User and verify that the Retailer – Supply Chain Collaboration Administrator authority profile is assigned.
- Select Tasks → Company → User. Create or open the user record, enter the mandatory details, and assign the ORACLE AUTHORIZED user role.
- Select Save and Close to trigger user synchronization.
- For a new user, use the IDCS email to set the password, then sign in to Supplier Evaluation and accept the terms and conditions.
- Allow the RSCH User Sync batch jobs to complete. Check the status in Batch Jobs.
- Ask the POM administrator to run ORCV_PRFL_IDCS_SYNC_JOB and confirm successful completion.
- Sign out of Supplier Evaluation and sign back in.
- Select Tasks → Merchandising → Home to open Supply Chain Hub.
- If additional RSCH applications are required, an administrator must configure the user’s Application Access and Application Permissions in Profile → Users.
For more details, see the Oracle Retail Supply Chain Collaboration Cloud Service Integration User Guide and Oracle Retail Supply Chain Collaboration Cloud Service Administration Guide.
Users associated only with Partner suppliers will not be given access to Supply Chain Hub.There are two ways to view the association of a user with a supplier.
View the Supplier Screen
To view a supplier’s user allocation:
- From the side menu, choose Profile.
- In the Suppliers tab, select the supplier.
- In the Supplier View screen, select the Users tab.
View the User Screen
To view a user’s supplier allocation:
- In the Users tab, select the user.
- In the User View screen, select the Suppliers tab.
