Filter Jobs in the Right-Side Menu
To view and search for jobs:
- From the side menu, select Quality Control. The dashboard screen is displayed.
The right-side menu is visible by default. - In the filter by Status and/or Location and/or Supplier, the filter availability depends on the user’s permission:
- Status:
- If the user is a Retailer User, the user can filter on status: New, In Execution, Canceled, Submitted, Completed, and Completed with issues.
- If the user is a Supplier User, the user can filter on status: Completed, and Completed with issue
If the user is a supplier, the data displayed in the table will only be related to jobs for suppliers for which the user has permission. - Supplier:
- Dropdown list of Suppliers
- Dropdown list of Locations
The list available for location or supplier depends on the user permission set up in the user profile.
The filter only applies to the jobs in the table; the values in the dashboard are not affected.
- Purchase Order
- ASN
- Item
For Purchase Order, ASN, and Item Filtering. multiple values can be entered. By default, Space is the delimiter of IDs, however it can be modified using a System Parameter. For details, see the Oracle Retail Supply Chain Collaboration Cloud Service Implementation Guide. - Status:
