Filter Penalties using the Right-Side Menu
To view and search for penalties:
- From the side menu, select Supplier Penalties. The dashboard screen is displayed.
- In the filter by Status and/or Supplier, the filter values availability depends on the user’s permission:
- Status:
- If the user is a retailer, the user can filter on status: Awaiting Retailer Approval, Rejected, Awaiting Supplier Approval, Rejected by Supplier, Approved, Canceled, Closed, and Error.
- If the user is a supplier, the user can filter on status: Awaiting Supplier Approval, Rejected by Supplier, Approved, Canceled, Closed, and Error.
If the user is a supplier, the data displayed in the table will only be related to penalties for suppliers for which the user has permission.
The filter only applies to the penalties in the table. The values in the dashboard are not affected.
- Supplier:
- Dropdown list of Suppliers
The list available for supplier depends on the user permission set up in the user profile.
- Status:
