Range Tab
To add locations for the item that is ranged:
- In the Range tab, click the + icon. (This tab is not available to Suppliers.)
- In the Add Locations dialog box, enter the following information:
- Location Type - choose between the available values:
- All Stores
- Store
- All Warehouses
- Warehouse
- Location List
- Location
- Status - choose between the available values:
- Active
- Discontinued
- Location
- If CFAs are also maintained at the Item Location level, they are available by selecting one record and clicking the Range CFA button, if available.
CFAs need to be set up in MFCS, configured and enabled using a System Parameter in Supply Chain Hub. For the necessary System Parameter configurations, see the Oracle Retail Supply Chain Collaboration Cloud Service Implementation Guide. Also see the Oracle Retail Merchandising Cloud Extensions Framework Implementation Guide on My Oracle Support.
