Upload Items
Alternatively, to using the front-end screens to create/update items, the users can choose to do the actions using the spreadsheet upload. This allows them to do multiple changes at the same time, in a single step.
CFAs need to be set up in MFCS, configured and enabled using a System Parameter in Supply Chain Hub. Additionally, the Upload/Download CFA tabs also need to be enabled if the CFAs are going to be used. For the necessary System Parameter configurations, see the Oracle Retail Supply Chain Collaboration Cloud Service Implementation Guide. Also see the Oracle Retail Merchandising Cloud Extensions Framework Implementation Guide on My Oracle Support.
