Activities Option
To navigate to the activities you need to complete, you can select the Activities option on the Proxess menu. When you select this option, a tab opens with a list view of Activities that meet the following requirements:
  • The External Role is set to Supplier Responsible.
  • The supplier or site is named in the Process.
You can also select the Processes option on the Process menu and then open activities from the Activities page.
