Copying a Process
To copy a process:
  1. Select the process in the left panel and select the Copy action. The Copy Process dialog box appears.
  2. Enter the number of copies that are required. Click Ok. The dialog box is updated with a Process Title field for each copy.
  3. Enter the titles and click Ok. A tab is opened for each new process.
  4. For each new process, make updates as needed and then select the Save action. A new process is created at the same hierarchy level as the process being copied.
