Moving a Process
A process can be moved to a different parent process. To move a sub-process, open the sub-process in edit mode. Select the Change Parent Process action. The Select Parent Process dialog box appears. Select the new parent process, click Ok, and save the process.
Apart from the process name, the original data is retained. If you need to adopt information from the new parent, see Adopting Information from a Parent Process.
