Process Briefs
Within Processes and Activities, the Brief Extract action can be used to produce an extract containing the questions used. The extract can be based on new or previously saved selection criteria. Previous selection criteria that is no longer required can be deleted. The extract is saved in the Report Outputs area, and a link is emailed to the user.
A Brief Extract may also be scheduled as a report. See the Oracle Retail Supplier Evaluation Reports User Guide.
