Copying Assessment Responses
It is possible to populate the responses to an assessment’s questions with the responses given to another assessment of the same type.
The action is available to both retailer and supplier users, in assessments which are at Future or In Progress status.
- Open the assessment in edit mode.
- Select the Select Assessment action. A list of assessments of the same type as the one being edited, for the sites that the user has access to, is presented.
- Select the assessment to be copied and click Ok. The assessment is validated, and a list of any non-matching questions is presented.
- Click Ok to confirm the copy. The responses are populated with those of matching questions in the selected assessment (any existing responses are overwritten). The assessment is again validated and saved. If its status was Future, it is set to In Progress.
