Integration with Merchandising
The system can be configured to integrate item/product records with Merchandising. If enabled, when a new Style or SKU level item is activated in Merchandising, it is automatically created in Supplier Evaluation as a Product Record. If CFA filtering is enabled, an item must also contain the configured Item Header CFA attribute and value before it can be created or synchronized in Supplier Evaluation. The Merchandising item code is held in the Product Codes table as the common reference between Supplier Evaluation and Merchandising.
Subsequent updates of the item description in Merchandising are automatically synchronized with the Supplier Evaluation Product Record, where it is read only. The description in the Business Language field is populated with the Merchandising item name when the record is created, but thereafter it is not synchronized, it is manually edited.
For configuration guidance and information on the glossaries and system parameters used for the integration with Merchandising, see the Oracle Retail Supply Chain Collaboration Cloud Service Administration Guide.
