Additional Assessment Filter Options
Additional filters can be applied to the assessment KPIs detailed above to alter the KPI metric criteria. These relate to the Assessment Scores Latest/Completed query.
These filters can be set against the KPI Report Template record and/or Report Schedule record.
Completed within last seven days
Filters to just the records with a Completed Date within the last seven days. This should be used with a filter on the Status column checking that it is set to Completed.
| Column | Operator | Type | Value | Unit | Logic |
Completion Date |
Greater Than |
Relative |
-7 |
Day |
and |
Completion Date |
Less than or Equal To |
Relative |
0 |
Day |
and |
Due date in the next seven days
Filters to just records with a Due Date in the next seven days.
Due Date |
Greater Than |
Relative |
0 |
Day |
and |
Due Date |
Relative |
7 |
Day |
and |
For Supplier Evaluation Type
Filters to just records with the specified Supplier Evaluation Type.
Supplier Evaluation Type |
Equals |
Fixed |
“Supplier Evaluation Type” |
and |
