Creating a Report Output Folder
To create a report output folder:
Select an existing folder in the left hand pane, under which the new folder is to appear.
Select the New Folder action in the left hand pane. The Enter Folder Name dialog box appears.
Figure 3-21 Folder Name Dialog Box
Enter the folder name and any language translations.
To continue, click Ok. To return to the Report Outputs page, click Cancel.
