Deleting a Report Output Folder
To delete a report output folder:
Choose the folder and select the Delete Folder action in the left hand pane. A delete confirmation dialog box appears. If the folder contains report outputs, they will also be deleted, in which case the message Deleting the folder will delete all reports/KPIs within it is shown.
Figure 3-22 Confirm Delete Folder
To continue with the deletion, click Ok. To return to the Report Outputs page, click Cancel.
