Deleting Report Outputs
Reporting administrators may delete any report output record; reporting users may delete only those that they have scheduled.
To delete a report:
  1. Check the report to be deleted (more than one may be selected).
  2. Select the Delete action. A Delete Document dialog box appears.
  3. To continue the deletion, click Ok. To return to the Report Outputs page, click Cancel.
Alternatively, open the report output record in edit mode and select the Delete action.
