Library
| List View | Default View | Retailer View | Supplier View | Summary |
| Document Library | ||||
Documents (Administrator Default) |
Yes | Yes | No |
The retailer administrator’s view of documents grouped within Folders. A document may appear in more than one folder. The filter chips can be used to locate those at a specific status. The filter tiles can be used to locate those that you have yet to read or accept, those that are mandatory, and whether visible to external (supplier) and/or internal (retailer) users. The folder actions include options to create, edit, and delete folders. The document actions include the standard set of options for the maintenance of Documents. Also includes options to assign the documents to folders, archive documents, and to view the readership and acceptance logs. The info panel contains basic information from the Document and its parent Folder, in separate tabs. Note: Initially, just the top level nodes are loaded; the child nodes are then loaded on demand, when choosing to expand a parent node. |
Documents (Retailer User Default) |
Yes | Yes | No |
The retailer user’s view of documents grouped within Folders. A document may appear in more than one folder. The filter chips can be used to locate those at a specific status. The filter tiles can be used to locate those that you have yet to read or accept, and those that are mandatory. The actions include options to mark the document as read or accepted, where required, and to view the readership and acceptance logs. The info panel contains basic information from the Document and its parent Folder, in separate tabs. Note: Initially, just the top level nodes are loaded; the child nodes are then loaded on demand, when choosing to expand a parent node. |
Documents (Supplier User Default) |
Yes | No | Yes |
The supplier user’s view of documents grouped within Folders. A document may appear in more than one folder. The filter chips can be used to locate those at a specific status. The filter tiles can be used to locate those that you have yet to read or accept, and those that are mandatory. The actions include options to mark the document as read or accepted, where required. The info panel contains basic information from the Document and it parent Folder, in separate tabs. Note: Initially, just the top level nodes are loaded; the child nodes are then loaded on demand, when choosing to expand a parent node. |
