List View Contents
The list view is a grid of rows and columns, where the rows represent individual records of a common type, and the columns represent the fields within the records.
To action a record, single-click the row; to open a record in read mode, double-click the row.
Columns can be resized by dragging the borders of the column heading; alternatively, right-click the row and use the Resize options.
Click a column heading to sort the list view contents in ascending order by that column; click again to sort in descending order. Alternatively, right-click the column and use the Sort Column options. Sorting is usually case-insensitive.
The filter tiles and searches are applied independently. If the list is filtered with a simple or advanced search, then a filter tile is clicked, the list will be refreshed based on the filter tile's criteria, and the search filter is cleared.
Columns for rich text fields truncate the content to fit the column width. Columns for Boolean fields show the true/false values as Yes/No accordingly.
