View Selector
The system is delivered with a set of predefined list views for each type of record (see Appendix: System List Views), which may be customized by the administrator. You may also create your own custom variants of the views (see Customization).
The name of the list view is shown in the title bar next to the name of the type of record being presented. Use the selector to switch to an alternative view.
