7 Data Extraction
Once the merchant's Xstore Office Cloud Service licence expires, the hosted data can be requested via a service request (SR).
The servicing technician can use Oracle Data Pump to extract the data like in the following example.
expdp dbauser/dbapass@MyCloudDB schemas=XCENTER,XADMIN,XCENTER_REPLICATION directory='/u01/app/oracle/oradata/' dumpfile=xoffice.dmp logfile=expdp-office.log
If the Xcenter application is still running and the data is small enough to download (several GBs), the resulting DMP file can be placed for download in a directory like /u02/app_files/pospoll, which is a directory configured in /usr/local/xcenter-config/xcenter.properties.
The file could then be downloaded like GET:
https://<host>:<port>/<tenancy_id>/xcenter/rest/DEFAULT/20/file/pospolls/EXPDAT01.DMP
where <tenancy_id> references the prod, stage or dev (or uat) environment.
