Documentation Conventions Overview
The following explains the conventions used in the Oracle Retail Xstore Point of Service Classic Manager's Guide.
Table 1-1 Documentation Conventions in the User Guide
| When you see... | Then... |
Select xxxxx |
This refers to a menu button or list option displayed on the Xstore Classic application screen. The bold text is the button or menu option text. Since all menu text is configurable, the text you see on your screen may be different from the text used in the procedure. |
Press xxx |
This refers to a key on the keyboard. The text is the name of the key. |
Blue, underlined text |
This indicates the tagged text is a link to another area of the user document. Click on the link to jump to related information. This feature is used when viewing the document online. For printed documents, a page number has also been provided. |
