30 Price Inquiry
If you want to look up the price of an item, use the function Price Inquiry. You can look up the price for an item when you are logged out.
To look up the price of an item, follow the steps below.
Select Price Inquiry from the Context Menu outside of login or select the Price Inquiry Quick Action Buttons.
Figure 30-1 Price Inquiry Quick Action Button
You are prompted for the item. Scan, or enter the item and press OK.
Figure 30-2 Price Inquiry Item Prompt
The item description, item ID and the corresponding price are displayed.
Figure 30-3 Price Inquiry Result
If the displayed price is a deal price, the system marks the price with the text Sale.
Figure 30-4 Price Inquiry- Deal Price
Select Back to close the screen.
