Configuring an Attachment Export
An attachment type is configured by the class AttachmentExportConfigforeach attachment type and passed as a property to the class AttachmentExportDataTask along with export URI and the organization
id which are configured in xcenter.proprties file.
AttachmentExportDataTask bean id is the value
for the key"integrationConfigId" to schedule the
spring job.
Table F-1 AttachmentExportConfig Settings
| Type | Position | Type | Meaning |
Property |
attachmentType |
String |
The attachmentType value should map the ATTACHMENT_TYPE column value of the TRN_TRANS_ATTACHMENT table. |
Property |
fileName |
String |
The file name for the extracted attachment. The name can be generated using the transaction attributes, tokens which are enclosed within parenthesis i.e ${PosTransactionModelProperty} are replaced with values from PosTransactionModel object and other tokens are treated as a static value. For organization ID 1000 and store ID 703 and transaction sequence 1539 the following file name configuration will generate file name 1000-703-1-TSE_STORAGE_BYTES-1539.tar.gz |
Property |
extractDirectory |
String |
The attachment extract directory is relative to the path {xst.fileresource.path.attachment} configured in xcenter.properties file. |
Table F-2 AttachmentExportData Task Settings
Property |
organizationId |
String |
Organization id property {xcenter.org.id} configured in xcenter.properties file. |
Property |
attachmentConfig |
bean |
The value of this property should be the same as the bean name for the relevant AttachmentExportConfig |
Property |
exportUri |
String |
The export URI property {xst.fileresource.path.attachment} configured in xcenter.properties file. |
Table F-3 Trigger Settings
Property |
String |
The value of this property should be the same as the bean name for the relevant AttachmentExportDataTask. |
Property |
String |
Cron expression. By default Configured to run once every 24 hours at 06:00. |
Property |
String |
Time zone property. Timezones are set to UTC/GMT and cronExpressions are expected to represent that time.. |
To enable the attachment export, add the configured JobDetailFactoryBean to jobsList and CronTriggerFactoryBean to triggersList as reference property list for relevant attachment type.
Export URI:
https://{hostname}:{port}/xcenter/rest/attachmentExample: The following are configurations which need to be done for each attachment type to export it to filesystem in xcenter-spring-beans.xml. The configuration below is for Germany TSE export.
<bean id="tseAttachmentExportConfig" class="com.micros_retail.xcenter.fiscalization.attachment.AttachmentExportConfig">
<!-- The attachmentType value should maps to the ATTACHMENT_TYPE column value of the TRN_TRANS_ATTACHMENT table. -->
<property name="attachmentType" value="TSE_STORAGE_BYTES" />
<!-- The file name for the extracted attachment. The name can be generated using the transaction attributes,
sequence 1539 the following file name configuration will generate file name 1000-703-1-TSE_STORAGE_BYTES-1539.tar.gz -->
<property name="fileName" value="${organizationId}-${retailLocationId}-${workstationId}-${attachmentType}-${transactionSequence}-${TSE_FISCAL_NUMBER}.tar.gz" />
<!-- The attachment extract directory is relative to the path {xst.fileresource.path.attachment} configured in xcenter.properties -->
<property name="extractDirectory" value="${organizationId}/${retailLocationId}/${workstationId}/${attachmentType}" />
</bean>
<bean id="tseAttchmentExportDataTrigger" class="org.springframework.scheduling.quartz.CronTriggerFactoryBean">
<property name="jobDetail" ref="tseAttachmentExportDataJob" />
<!-- Configured to run once every 24 hours at 06:00. -->
<property name="cronExpression" value="0 0 6 * * ?" />
<!-- Timezones are set to UTC/GMT and cronExpressions are expected to represent that time. -->
<property name="timeZone" value="UTC" />
</bean>
<bean id="tseAttachmentExportDataTask" class="com.micros_retail.xcenter.fiscalization.attachment.AttachmentExportDataTask">
<property name="organizationId" value="#{T(com.micros_retail.xcenter.bootstrap.XcenterProperties).getString('xcenter.org.id')}" />
<!-- The value of this property should be the same as the bean name for the relevant tseAttachmentExportConfig -->
<property name="attachmentConfig" ref="tseAttachmentExportConfig" />
<property name="exportUri" value="#{T(com.micros_retail.xcenter.bootstrap.XcenterProperties).getString('xst.fileresource.path.attachment')}" />
</bean>
<bean id="tseAttachmentExportDataJob" class="org.springframework.scheduling.quartz.JobDetailFactoryBean">
<property name="jobClass" value="com.micros_retail.xcenter.integration.IntegrationJob" />
<property name="jobDataAsMap">
<map>
<entry key="category" value="INTEGRATION" />
<!-- The value of this property should be the same as the bean name for the relevant tseAttachmentExportDataTask -->
<entry key="integrationConfigId" value="tseAttachmentExportDataTask" />
</map>
</property>
<property name="durability" value="true" />
<property name="description" value="Export Transaction Attachment Data" />
</bean>
