If Not Using Xcenter to Get the Config Path
If retrieval of the config path from Xcenter is not being used the config path is still assembled in the same manner outlined above. The difference is that the properties xstore.config.path.base.features and xstore.config.path.overrides.workstation.# (where # is a workstation ID) are not retrieved from Xcenter.
If Oracle Retail Xstore Point of Service ever used Xcenter to obtain the config path, and the configPath.properties file contains properties those properties will continue to be used even if updating from Xcenter is turned off. They will no longer be updated from Xcenter.
