Job Management
The Job Management screen enables you to view scheduled quartz jobs and their status.
From the Oracle Retail Xstore Office Cloud Service menu, select System Management, then System Manager, and Jobs or click the System Manager link in the System panel, and then select Jobs.
The Job Management page is displayed, detailing jobs currently scheduled. The jobs displayed in the Job Summary table are only for the organizations the user has access to. By default the jobs are sorted by last run time. If the last run time is null for both comparing jobs, then the jobs are sorted by job name.
Figure 3-4 Job Management
You can filter the jobs by:
Job Name
The Job Name column displays the defined job description for the scheduled job.
Job Category
This column displays the job category.
Organization
The organization column displays the organization ID and organization name in which the job is impacting.
Only jobs for the organization(s) the user has access to are displayed, all other jobs are hidden.
If the job spans across the entire implementation, this field is left blank.
Status
This column displays the status of the job. Possible statuses include:
None
Normal
Complete
Paused
Error
Blocked
Last Run Time
This column displays the UTC date-time stamp of the last run time of the job.
Next Run
This column displays the UTC date-time stamp of the next run time of the job.
Select Search. The data that matches the filter criteria is displayed in the table.
Select Reset to reset the filter criteria and update the search result in the table with the latest data.
