Overview
This Xcenter feature extracts files from the trn_trans_attachments table and places them in a configured location on the filesystem.
The retailer can access the exported files in the file system via REST webservice call.
Several functions are exporting data in the trn_trans_attachments table. As base we are providing a basic configuration for Germany TSE data as reference. The retailer can configure the export filename, export directory and separate configuration to trigger each attachment type export. These configuration will be maintained in xcenter-spring-bean.xml.
