Configuring Device Configuration Types
This portal is used to display and maintain a Device Configuration Type.
Refer to Understanding Device Configuration Types for more information.
You can access the portal by selecting Admin, then Device, then Device Configuration Type.
- Device Configuration Type List: This zone lists all Device Configuration Type records. Broadcast a record to display the details of the selected record.
- Device Configuration Type: This zone provides information about the selected Device Configuration Type.
