Upgrade Tech Stack for Source Application
This page details all the tasks required to upgrade the source database and GoldenGate to 19C.
On this page:
Upgrade Database to 19C
Note: Upgrade the source database to 19C if the source application is compatible with both Oracle Database 19C and GlodenGate 19C.
Task
Description
Download and Upgrade Oracle Database Server Enterprise
  1. Download Oracle Database Server Enterprise Edition 19C from Oracle Software Delivery Cloud to a temporary directory.
  2. Upgrade the database to 19C.
Download and apply the Database Server Patch
  1. Download the Database Server Patch 32545013 from My Oracle Support to a temporary directory.
  2. Export the ORACLE_HOME set to the Database Server installed path.
  3. Unzip the patch, navigate to the patch top directory, and run the following:
    Copy
    $ORACLE_HOME/OPatch/opatch apply
Back to Top
Upgrade GoldenGate to 19C
Notes:
  • Before upgrading, back up the current environment and ensure you have a rollback plan.
  • Make sure the same OS user installs all software, and replace all parameters enclosed in <> with the appropriate values.
  • While the table below includes some directory structures as examples, you can choose where to install the software. Make sure to keep track of all the home directories you create, as these will be used for OUAW installation.
Task
Description
Download and Upgrade the Java Development Kit
  1. Download the Oracle Java Development Kit (JDK) 1.8 version (for example: JDK 1.8.0.291) from Oracle Technology Network to a temporary directory.
  2. Upgrade the JDK to JDK 1.8.0 (291).
Download and install GoldenGate
  1. Rename the current GoldenGate Home directory.
  2. Download Oracle GoldenGate 19.1 from Oracle Software Delivery Cloud to a temporary directory. See Install GoldenGate for details.
  3. Install Oracle GoldenGate in a customized location within the source database server. Use the same directory name as for the previously installed GolgenGate Home.
    Example: </u01/ouaw/goldengate>
    Note: This will be referred to as Oracle GoldenGate Home.
Download and install GoldenGate Monitor Agent
GoldenGate Monitor Agent Installation Steps:
  1. Rename both the GoldenGate Monitor Agent and the GoldenGate Monitor Agent instance homes.
  2. Download Oracle GoldenGate Monitor Agent 12.2.1.2 from Oracle Software Delivery Cloud to a temporary directory.
  3. Choose "Oracle GoldenGate Monitor Agent" as the installation type when installing onto a customized location. Use the same directory name as for the previously installed GolgenGate Monitor Agent home.
    Example: </u01/ouaw/oggagent>.
    Note: This location will be referred to as Oracle GoldenGate Monitor home.
Apply patch for GoldenGate Monitor Agent
  1. Download and apply patch 26982776 from My Oracle Support to Oracle GoldenGate Monitor Agent.
  2. Set the ORACLE_HOME to the Oracle GoldenGate Monitor Agent home install location.
  3. Unzip the patch, navigate to the patch top folder, and run the following:
    Copy
GoldenGate Monitor Agent Configuration
Edit the configuration template:
  1. Go to <Oracle GoldenGate Monitor Agent home>/oggmon/ogg_agent/cfg_templates directory and open the Config.properties file.
  2. Modify the parameters using the following values:
    ACTUAL: jagent.host=localhost
    CHANGE TO: jagent.host=<<actual hostname on which Oracle GoldenGate is installed>>
    ACTUAL: monitor.jmx.username=oggmsjmxusr
    CHANGE TO: monitor.jmx.username=jmx_src
    ACTUAL: jagent.username=oggmajmxusr
    CHANGE TO: jagent.username=<<Oracle GoldenGate software installed OS user>>
    ACTUAL: jagent.rmi.port=5559
    CHANGE TO: jagent.rmi.port=5557 (or any free port other than the one on which the rmiregistry is started)
    ACTUAL: agent. type.enabled=OGGMON
    CHANGE TO: agent.type.enabled=OEM
Create the GoldenGate Monitoring Agent instance:
  1. Navigate to <Oracle GoldenGate Monitor home>/oggmon/ogg_agent.
  2. Run the createMonitorAgentInstance.sh script. Example execution:
    Copy
    cd <Oracle GoldenGate Monitor home>/oggmon/ogg_agent
    ./createMonitorAgentInstance.sh
  3. When prompted, enter the following information:
    • Oracle GoldenGate home directory: <GoldenGate Home location>
    • Path to be used for Oracle GoldenGate Monitor Agent instance.
      Example: </u01/ouaw/ogginstance>.
      Note: This will be referred to as the Oracle GoldenGate Monitor instance home.
    • A unique name to replace the timestamp in the name of the file used to start the Oracle GoldenGate Monitor agent instance.
Create JAgent wallet:
  1. Navigate to <Oracle GoldenGate Monitor Agent instance Home>/bin.
  2. Add JAVA_HOME/bin to the PATH variable.
    Copy
    export JAVA_HOME=<JAVA HOME PATH>
    export PATH=$JAVA_HOME/bin:$PATH
  3. Run the pw_agent_util.sh script. Example execution:
    Copy
    cd  <Oracle GoldenGate Monitor Instance>/bin
    ./pw_agent_util.sh -jagentonly
  4. Enter the Oracle wallet password. This password has to be entered as the password for the JAgent while running the OUAW installer.
  5. Store the password for future reference.
Set Up Oracle GoldenGate
  1. In the command window, navigate to the Oracle GoldenGate Home directory.
  2. Edit the GLOBALS file in the directory and add the following command: EnableMonitoring. Save the file.
  3. Navigate to GoldenGate home and look for directories (dirprm, dirdat, dirrpt, and so on).
    If these directories do not exist, connect to the ggsci prompt and execute the statement below to create them.
    Copy
    export ORACLE_HOME=<ORACLE HOME>
    export PATH=$ORACLE_HOME/bin:$PATH
    ./ggsci
    CREATE SUBDIRS
    start mgr
Configure and Start GoldenGate JAgent
Note: Perform the steps below in case rmiregistry services are not running. Use the same RMI Registry port that was used before upgrade.
  1. Start the rmiregistry services using the commands below.
    Copy
    set JAVA HOME and PATH
    export JAVA_HOME=<JAVA_HOME>
    rmiregistry <port number> &
    Example: rmiregistry 5559 &
  2. Navigate to <GoldenGate Home>/dirprm and edit the jagent.prm file. Replace COMMAND java  with COMMAND <JAVA_HOME>/bin/java.
  3. Navigate to <GoldenGate Home> and run the command below.
    Copy
    export ORACLE_HOME=<ORACLE_HOME>
    ./ggsci
    START JAGENT
Back to Top
