Fact Tables
This section lists the fact tables.
Billed Usage
Stores the information of the financial transactions and the usage associated with corresponding bills and bill segments.
Entity Relationship Diagram
Properties
Property
Value
Target Table Name
CF_BILLED_USAGE
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_FT
Stage Table Name
STG_CF_BILLED_USAGE
ODI Package Name
B1_PKG_CF_BILLED_USAGE
ETL View Name
B1_F_BILLED_USAGE_VW
Materialized View Name
B1_BILLEDUSAGE_MON_MV1
B1_BILLEDUSAGE_MON_TOPX_MV1
Fields
Target Field
OAS Field
Source Field
Transformation
BILLED_USAGE_KEY
Billed Usage Key
This field is populated with the sequence from SPL_BILLED_USAGE_SEQ.
SRC_BILL_ID
Bill ID
CI_FT.PARENT_ID
SRC_BSEG_ID
Bill Segment ID
CI_FT.SIBLING_ID
SRC_FT_ID
Financial Transaction ID
CI_FT.FT_ID
SRC_SQI_CD
Service Quantity Identifier Code
SRC_TOU_CD
Time of Use Code
SRC_UOM_CD
Unit of Measure Code
SRC_RATE_SCHED_
CD
Rate Schedule Code
This field is populated with the rate code from bill segment calculation header.
Every primary non-null rate schedule code on the bill segment calculation header leads to a new row in this fact.
BILLED_QTY
Billed Quantity
CI_BSEG_SQ.BILL_SQ
CI_BSEG_READ.
FINAL_REG_QTY
If there is a single primary rate on bill segment calculation headers, use Bill SQ value from Bill Segment Service Quantity. Else, for each rate, for each usage period, sum up the Final Registered Quantity from bill segment read for the UOM/TOU/SQI combination.
CALC_AMT
Calculated Amount
CI_BSEG_CALC_LN.
CALC_AMT
CI_BSEG_CALC.
CALC_AMT
If single primary rate, sum up the calculation amount from bill segment calculation lines. Else, for each rate, calculate the sum of calculation amounts for the UOM/TOU/SQI of the calculation header's usage period.
Note: The amounts are grouped on the UOM/TOU/SQI combination.
CURRENCY_CD
Currency Code
CI_FT.CURRENCY_
CD
FACT_CNT
Fact Count
This field is populated with the standard value of ‘1’.
INIT_QTY
Initial Quantity
CI_BSEG_SQ.INIT_SQ
CI_BSEG_READ.MSR_QTY
If there is a single primary rate single on bill segment calculation headers, use initial SQ value from bill segment service quantity. Else, for each rate, for each usage period, sum up the Measured Quantity from bill segment read for the UOM/TOU/SQI combination.
SEG_DAYS
Bill Segment Days
This field is populated with the difference between the end date and the start date of the respective bill segment.
SA_KEY
Service Agreement Dimension Surrogate Key
CI_FT.SA_ID
This field is populated with the service agreement on the financial transaction.
ACCT_KEY
Account Dimension Surrogate Key
CI_SA.ACCT_ID
This field is populated with the account on the service agreement for which the bill segment was generated.
PER_KEY
Person Dimension Surrogate Key
CI_ACCT_PER.PER_
ID
This field is populated with the main customer of the respective account.
ADDR_KEY
Address Dimension Surrogate Key
This field is populated with the characteristic premise on the service agreement. If not found, the mailing premise ID on the account is used.
BILL_DATE_KEY
Date Dimension Surrogate Key
CI_BILL.CRE_DTTM
This field is populated with the creation date of the bill associated with the bill segment.
BSEG_STRT_DATE_KEY
CI_BSEG.START_DT
This field is populated with the start date of the respective bill segment.
BSEG_END_DATE_KEY
CI_BSEG.END_DT
This field is populated with the end date of the respective bill segment.
FISCAL_CAL_KEY
Fiscal Period Dimension Surrogate Key
CI_GL_DIVISION.CALANDER_CD
This field is populated with the calendar code from GL_DIVISION based on the input accounting date.
PREM_KEY
Premise Dimension Surrogate Key
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
RATE_KEY
Rate Dimension Surrogate Key
CI_BSEG_CALC.RS_
CD
This field is populated with rate code from the bill segment calculation header.
SQI_KEY
Service Quantity Identifier Dimension Surrogate Key
CI_BSEG_SQ.SQI_CD
This field is populated with the SQI code associated with bill segment service quantity.
TOU_KEY
Time of Use Dimension Surrogate Key
CI_BSEG_SQ.TOU_CD
This field is populated with the TOU code associated with bill segment service quantity.
UOM_KEY
Unit of Measure Dimension Surrogate Key
CI_BSEG_SQ.UOM_
CD
This field is populated with the UOM code associated with bill segment service quantity.
BUSG_UDD1_KEY
Bill Segment Usage User Defined Dimension 1 Surrogate Key
BUSG_UDD2_KEY
Bill Segment Usage User Defined Dimension 2 Surrogate Key
UDM1
User Defined Measure 1
CI_FT.FREEZE_DTTM
CI_BSEG.END_DT
This field is populated with the bill lag. Bill lag is calculated as the difference between the bill segment freeze (financial transaction freeze date) and the meter read date (bill segment end date).
UDM2
User Defined Measure 2
UDM3
User Defined Measure 3
UDM4
User Defined Measure 4
UDM5
User Defined Measure 5
UDM6
User Defined Measure 6
UDM7
User Defined Measure 7
UDM8
User Defined Measure 8
UDM9
User Defined Measure 9
UDM10
User Defined Measure 10
UDM11
User Defined Measure 11
UDM12
User Defined Measure 12
UDM13
User Defined Measure 13
UDM14
User Defined Measure 14
UDM15
User Defined Measure 15
UDM16
User Defined Measure 16
UDM17
User Defined Measure 17
UDM18
User Defined Measure 18
UDM19
User Defined Measure 19
UDM20
User Defined Measure 20
UDDGEN1
User Defined Degenerate Dimension 1
UDDGEN2
User Defined Degenerate Dimension 2
UDDGEN3
User Defined Degenerate Dimension 3
UDDGEN4
User Defined Degenerate Dimension 4
UDDGEN5
User Defined Degenerate Dimension 5
UDDGEN6
User Defined Degenerate Dimension 6
UDDGEN7
User Defined Degenerate Dimension 7
UDDGEN8
User Defined Degenerate Dimension 8
UDDGEN9
User Defined Degenerate Dimension 9
UDDGEN10
User Defined Degenerate Dimension 10
UDDGENL1
User Defined Long Degenerate Dimension 1
UDDGENL2
User Defined Long Degenerate Dimension 2
UDDGENL3
User Defined Long Degenerate Dimension 3
UDDGENL4
User Defined Long Degenerate Dimension 4
UDDGENL5
User Defined Long Degenerate Dimension 5
UDDGENL6
User Defined Long Degenerate Dimension 6
UDDGENL7
User Defined Long Degenerate Dimension 7
UDDGENL8
User Defined Long Degenerate Dimension 8
UDDGENL9
User Defined Long Degenerate Dimension 9
UDDGENL10
User Defined Long Degenerate Dimension 10
UDDGEN_NUM1
User Defined Numeric Degenerate Dimension 1
UDDGEN_NUM2
User Defined Numeric Degenerate Dimension 2
UDDGEN_NUM3
User Defined Numeric Degenerate Dimension 3
UDDGEN_NUM4
User Defined Numeric Degenerate Dimension 4
UDDGEN_NUM5
User Defined Numeric Degenerate Dimension 5
UDDGEN_NUM6
User Defined Numeric Degenerate Dimension 6
UDDGEN_NUM7
User Defined Numeric Degenerate Dimension 7
UDDGEN_NUM8
User Defined Numeric Degenerate Dimension 8
UDDGEN_NUM9
User Defined Numeric Degenerate Dimension 9
UDDGEN_NUM10
User Defined Numeric Degenerate Dimension 10
UDDFK1_KEY
User Defined Dimension Foreign Key 1
UDDFK2_KEY
User Defined Dimension Foreign Key 2
UDDFK3_KEY
User Defined Dimension Foreign Key 3
UDDFK4_KEY
User Defined Dimension Foreign Key 4
UDDFK5_KEY
User Defined Dimension Foreign Key 5
UDDFK6_KEY
User Defined Dimension Foreign Key 6
UDDFK7_KEY
User Defined Dimension Foreign Key 7
UDDFK8_KEY
User Defined Dimension Foreign Key 8
UDDFK9_KEY
User Defined Dimension Foreign Key 9
UDDFK10_KEY
User Defined Dimension Foreign Key 10
UD_DATE1
User Defined Date Field 1
UD_DATE2
User Defined Date Field 2
UD_DATE3
User Defined Date Field 3
UD_DATE4
User Defined Date Field 4
UD_DATE5
User Defined Date Field 5
UD_DATE6
User Defined Date Field 6
UD_DATE7
User Defined Date Field 7
UD_DATE8
User Defined Date Field 8
UD_DATE9
User Defined Date Field 9
UD_DATE10
User Defined Date Field 10
UD_DATE1_KEY
User Defined Date Key Field 1
UD_DATE2_KEY
User Defined Date Key Field 2
UD_DATE3_KEY
User Defined Date Key Field 3
UD_DATE4_KEY
User Defined Date Key Field 4
UD_DATE5_KEY
User Defined Date Key Field 5
UD_DATE6_KEY
User Defined Date Key Field 6
UD_DATE7_KEY
User Defined Date Key Field 7
UD_DATE8_KEY
User Defined Date Key Field 8
UD_DATE9_KEY
User Defined Date Key Field 9
UD_DATE10_KEY
User Defined Date Key Field 10
JOB_NBR
Job Number
This field is populated with the ODI job execution session number.
DATA_SOURCE_IND
Data Source Indicator
B1_PROD_INSTANCE.DSI
This field is populated with the DSI value on the source product instance configuration. This table is populated as part of the initial setup and the DSI value is extracted from the environment ID of the source system (CI_INSTALLATION.ENV_ID).
Case
Stores all cases defined in the source system, and also their duration.
Properties
Property
Value
Target Table Name
CF_CASE
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_CASE
Stage Table Name
STG_CF_CASE
ODI Package Name
B1_PKG_CF_CASE
ETL View Name
B1_F_CASE_VW
B1_CASE_MON_MV1
B1_CASE_MON_MV2
B1_CASE_TOPX_MON_MV1
B1_CASE_TOPX_MON_MV2
Fields
Target Field
OAS Field
Source Field
Transformation Logic
ACCT_KEY
CI_CASE.ACCT_ID
ADDR_KEY
CI_CASE.PREM_ID
CASETY_STAT_KEY
Case Type Status Dimension Surrogate Key
CI_CASE.CASE_TYPE_CD
CI_CASE.CASE_
STATUS_CD
CASE_COND_KEY
Case Condition Dimension Surrogate Key
CI_CASE.CASE_COND_FLG
CASE_LEN
Duration
This field is populated with '0' if the case is open. Else, it is populated, in hours, with the difference between the closed date and the open date.
CASE_UDD1_KEY
Case User Defined Dimension 1 Surrogate Key
CASE_UDD2_KEY
Case User Defined Dimension 2 Surrogate Key
CASE_UDD3_KEY
Case User Defined Dimension 3 Surrogate Key
CASE_UDD4_KEY
Case User Defined Dimension 4 Surrogate Key
CASE_UDD5_KEY
Case User Defined Dimension 5 Surrogate Key
OPEN_DATE_KEY
CI_CASE_LOG.LOG_DTTM
This field is populated with the date of the open log for the respective case.
CLOSE_DATE_KEY
This field is populated only when the case is closed. It is populated with the maximum log date.
FACT_CNT
Fact Count
This field is populated with the standard value of “1”.
PER_KEY
CI_CASE.PER_ID
PREM_KEY
CI_CASE.PREM_ID
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
USER_KEY
User Dimension Surrogate Key
CI_CASE.USER_ID
CASE_KEY
Case Fact Key
This field is populated with the sequence from B1_CASE_SEQ.
SRC_CASE_ID
Case ID (Natural Key)
CI_CASE.CASE_ID
CURRENCY_CD
Currency Code
CI_INSTALLATION.CURRENCY_CD
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDGENL11
User Defined Long Degenerate Dimension 11
UDDGENL12
User Defined Long Degenerate Dimension 12
UDDGENL13
User Defined Long Degenerate Dimension 13
UDDGENL14
User Defined Long Degenerate Dimension 14
UDDGENL15
User Defined Long Degenerate Dimension 15
UDDGENL16
User Defined Long Degenerate Dimension 16
UDDGENL17
User Defined Long Degenerate Dimension 17
UDDGENL18
User Defined Long Degenerate Dimension 18
UDDGENL19
User Defined Long Degenerate Dimension 19
UDDGENL20
User Defined Long Degenerate Dimension 20
UDDGEN_NUM1
UDDGEN_NUM2
UDDGEN_NUM3
UDDGEN_NUM4
UDDGEN_NUM5
UDDGEN_NUM6
UDDGEN_NUM7
UDDGEN_NUM8
UDDGEN_NUM9
UDDGEN_NUM10
OPEN_TIME_KEY
Time Dimension Surrogate Key
This field is populated with the time of the open log for the respective case.
CLOSE_TIME_KEY
This field is populated with 'null' if the case is in open condition. If the case is closed, then it is populated with the maximum log time.
UDDFK1_KEY
User Defined Dimension Surrogate Key 1
UDDFK2_KEY
User Defined Dimension Surrogate Key 2
UDDFK3_KEY
User Defined Dimension Surrogate Key 3
UDDFK4_KEY
User Defined Dimension Surrogate Key 4
UDDFK5_KEY
User Defined Dimension Surrogate Key 5
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UD_DATE1
User Defined Date 1
UD_DATE2
User Defined Date 2
UD_DATE3
User Defined Date 3
UD_DATE4
User Defined Date 4
UD_DATE5
User Defined Date 5
UD_DATE6
User Defined Date 6
UD_DATE7
User Defined Date 7
UD_DATE8
User Defined Date 8
UD_DATE9
User Defined Date 9
UD_DATE10
User Defined Date 10
UD_DATE1_KEY
User Defined Date Key 1
UD_DATE2_KEY
User Defined Date Key 2
UD_DATE3_KEY
User Defined Date Key 3
UD_DATE4_KEY
User Defined Date Key 4
UD_DATE5_KEY
User Defined Date Key 5
UD_DATE6_KEY
User Defined Date Key 6
UD_DATE7_KEY
User Defined Date Key 7
UD_DATE8_KEY
User Defined Date Key 8
UD_DATE9_KEY
User Defined Date Key 9
UD_DATE10_KEY
User Defined Date Key 10
DATA_SOURCE_IND
JOB_NBR
Job Number
Case Log
Stores the case state transition changes in the source system. This fact captures information to indicate if the case is in initial or final state, the time the case was open, and the time the case spent in the previous state.
Properties
Property
Value
Target Table Name
CF_CASE_LOG
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_CASE_LOG
Stage Table Name
STG_CF_CASE_LOG
ODI Package Name
B1_PKG_CF_CASE_LOG
ETL View Name
B1_F_CASE_LOG_VW
B1_CASELOG_MON_MV1
Fields
Target Field
OAS Field
Source Field
CASELOG_KEY
Case Log Fact Key
This field is populated with the sequence from B1_CASE_LOG_SEQ.
CASE_LOG_SEQ
Case Log Sequence
CI_CASE_LOG.SEQ_NUM
SRC_CASE_ID
CI_CASE_LOG.CASE_ID
CURRENCY_CD
Currency Code
INITIAL_STATUS_
IND
Initial Status Indicator
CI_CASE_LOG.CASE_LOG_TYPE_FLG
This field is populated with '1' when the Log Type is “Created”. It is populated with '0' when the Log Type is “Status Transition”. Otherwise, it is populated with ‘0’.
FINAL_STATUS_IND
Final Status Indicator
This field is populated with ‘1’ when the Log Type is “Status Transition” and Case Condition Flag is “Closed”.
TIME_CASE_OPEN
Case Open Time
This field is populated with ‘0’ if the log type is “Created”. If the log type is “Status Transition”, it is populated, in hours, with difference between the current log date and the open log date.
TIME_IN_PREV_ST
Time in Previous Status
This field is populated with ‘0’ if the log type is “Created”. If the log type is “Status Transition”, it is populated, in hours, with the difference between the current log date and the previous “Status Transition” log date.
ACCT_KEY
CI_CASE.ACCT_ID
ADDR_KEY
CI_CASE.PREM_ID
CASETY_STAT_KEY
Case Log Type Status Dimension Surrogate Key
CI_CASE_LOG.CASE_TYPE_CD
LOG_DATE_KEY
Date Dimension Surrogate key
This field is populated using the date portion from the source.
LOG_TIME_KEY
This field is populated using the time portion from the source.
OPEN_DATE_KEY
This field is populated using the date portion of the “Created” log entry for the current case.
OPEN_TIME_KEY
This field is populated using the time portion of the “Created” log entry for the current case.
PER_KEY
CI_CASE.PER_ID
PREM_KEY
CI_CASE.PREM_ID
PV_CASETY_STAT_
KEY
CI_CASE_LOG.CASE_STATUS_CD
This field is populated only when the log type is “Status Transition”. It is populated with the case status code from the previous “Status Transition” log.
USER_KEY
CI_CASE_LOG.USER_ID
CASELOG_UDD1_
KEY
Case Log User Defined Dimension 1 Surrogate Key
CASELOG_UDD2_
KEY
Case Log User Defined Dimension 2 Surrogate Key
CASELOG_UDD3_
KEY
Case Log User Defined Dimension 3 Surrogate Key
CASELOG_UDD4_
KEY
Case Log User Defined Dimension 4 Surrogate Key
CASELOG_UDD5_
KEY
Case Log User Defined Dimension 5 Surrogate Key
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDGEN_NUM1
UDDGEN_NUM2
UDDGEN_NUM3
UDDGEN_NUM4
UDDGEN_NUM5
UDDGEN_NUM6
UDDGEN_NUM7
UDDGEN_NUM8
UDDGEN_NUM9
UDDGEN_NUM10
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UD_DATE1
UD_DATE2
UD_DATE3
UD_DATE4
UD_DATE5
UD_DATE6
UD_DATE7
UD_DATE8
UD_DATE9
UD_DATE10
UD_DATE1_KEY
UD_DATE2_KEY
UD_DATE3_KEY
UD_DATE4_KEY
UD_DATE5_KEY
UD_DATE6_KEY
UD_DATE7_KEY
UD_DATE8_KEY
UD_DATE9_KEY
UD_DATE10_KEY
DATA_SOURCE_IND
This field is populated with the DSI value on the source product instance configuration. This table is populated as part of the initial setup and the DSI value is extracted from the environment ID of source system (CI_INSTALLATION.ENV_ID).
JOB_NBR
Job Number
This field is populated with ODI job execution session number.
Note: Only the case logs with type as “Created” or “Status Transition” are retrieved.
Collectible Event
Stores the collection events, cut event, over due event, and severity event information.
Properties
Property
Value
Target Table Name
CF_COLL_EVT
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_COLL_EVT
CI_SEV_EVT
CI_OD_EVT
CI_CUT_EVT
Stage Table Name
STG_CF_COLL_EVT
ODI Package Name
B1_PKG_CF_COLL_EVT
ETL View Name
B1_F_COLL_EVT_VW
Fields
Source 1 - Collectible Event (CI_COLL_EVT)
Target Field
OAS Field
Source Field
COLL_EVT_KEY
Collectible Event Fact Surrogate Key
This field is populated with the sequence from B1_COLL_EVT_SEQ.
COLL_PROC_ID
Collection Process ID
CI_COLL_EVT.COLL_PROC_ID
All completed collection events (Status 30) are to be retrieved for this fact.
COLL_EVT_SEQ
Collection Event Sequence
CI_COLL_EVT.EVT_
SEQ
COLL_EVT_SRC_IND
Collectible Event Source Indicator
This indicator is set to ‘0’.
CURRENCY_CD
Currency Code
CI_ACCT.CURRENCY_CD
This field is populated with the account’s currency code.
ACCT_KEY
CI_COLL_PROC.ACCT_ID
ADDR_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
This field is populated with the mailing premise ID of the account. If not found, the characteristic premise on the service agreement is used.
CEVT_TYPE_KEY
Collectible Event Type Dimension Key
CI_COLL_EVT.COLL_EVT_TYP_CD
Prefix the Collection Event Type with ‘C_’ and store it in the column.
COLL_TMPL_KEY
Collectible Process Template Dimension Key
CI_COLL_PROC.COLL_PROC_TMPL_CD
Prefix the Collection Process Template Code with ‘C_’.
EVENT_DATE_KEY
CI_COLL_EVT.COMPLETION_DT
PER_KEY
CI_ACCT_PER.PER_
ID
This field is populated with the main customer of the account.
PREM_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
COLLEVT_UDD1_
KEY
Collectible Event User Defined Dimension 1 Surrogate Key
COLLEVT_UDD2_
KEY
Collectible Event User Defined Dimension 2 Surrogate Key
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDDGEN1
UDDGEN2
UDDGEN3
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Source 2 - Severance Event (CI_SEV_EVT)
Target Field
OAS Field
Source Field
COLL_EVT_KEY
COLL_PROC_ID
CI_SEV_EVT.SEV_PROC_ID
All completed severance events (Status 30) need to be retrieved for this fact
COLL_EVT_SEQ
CI_SEV_EVT.EVT_
SEQ
COLL_EVT_SRC_IND
This indicator is set to ‘1’.
CURRENCY_CD
Currency Code
CI_ACCT.CURRENCY_CD
ACCT_KEY
CI_SA.ACCT_ID
This field is populated with the account on the service agreement of the severence process.
ADDR_KEY
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
CEVT_TYPE_KEY
CI_SEV_EVT.SEV_
EVT_TYPE_CD
Prefix the severance event type code with ‘S_’ and use.
COLL_TMPL_KEY
Use the collection template corresponding to severance processes’ collection process ID and prefix it with ‘C_’.
EVENT_DATE_KEY
CI_SEV_EVT.COMPLETION_DT
PER_KEY
CI_ACCT_PER.PER_ID
PREM_KEY
CI_SA.CHAR_PREM_ID
CI_ACCT.MAILING_PREM_ID
COLLEVT_UDD1_
KEY
COLLEVT_UDD2_
KEY
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDDGEN1
UDDGEN2
UDDGEN3
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Source 3 - Overdue Event (CI_OD_EVT)
Target Field
OAS Field
Source Field
COLL_EVT_KEY
COLL_PROC_ID
CI_OD_EVT.OD_
PROC_ID
Completed overdue events (Status 30) are retrieved for this fact.
COLL_EVT_SEQ
CI_OD_EVT.EVT_
SEQ
COLL_EVT_SRC_IND
This indicator is set to ‘2’.
CURRENCY_CD
Currency Code
CI_ACCT.CURRENCY_CD
ACCT_KEY
CI_OD_PROC.ACCT_
ID
ADDR_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
This field is populated with the mailing premise ID of the account. If not found, use the characteristic premise from the service agreement.
CEVT_TYPE_KEY
CI_OD_EVT.OD_EVT_TYPE_CD
Prefix the overdue event type code with ‘OD_’ and use it.
COLL_TMPL_KEY
CI_OD_PROC.OD_
PROC_TMP_CD
This field is populated with Collection Process Template Code prefixed with ‘OD_’.
EVENT_DATE_KEY
PER_KEY
CI_ACCT_PER.PER_
ID
PREM_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
COLLEVT_UDD1_
KEY
COLLEVT_UDD2_
KEY
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDDGEN1
UDDGEN2
UDDGEN3
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Source 4 - Cut Event (CI_CUT_EVT)
Target Field
OAS Field
Source Field
COLL_EVT_KEY
COLL_PROC_ID
CI_CUT_EVT.CUT_
PROC_ID
All completed cut events are retrieved for this fact.
COLL_EVT_SEQ
CI_CUT_EVT.EVT_
SEQ
COLL_EVT_SRC_IND
This indicator is set to ‘3’.
CURRENCY_CD
Currency Code
CI_ACCT.CURRENCY_CD
ACCT_KEY
CI_SA.ACCT_ID
This field is based on the service agreement ID. It is populated with the respective account ID.
ADDR_KEY
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
This field is populated with the characteristic premise on the service agreement. If not found, the mailing premise mailing ID on the account is used.
CEVT_TYPE_KEY
CI_CUT_EVT.CUT_
EVT_TYPE_CD
Retrieve the cut event type code and prefix with ‘CUT_’ and use it.
COLL_TMPL_KEY
CI_OD_PROC.OD_
PROC_TMP_CD
Use the process template corresponding to cut processes’ overdue process ID and prefix with ‘OD_’.
EVENT_DATE_KEY
CI_CUT_EVT.CUT_EVT_STAT_DTTM
PER_KEY
CI_ACCT_PER.PER_
ID
PREM_KEY
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
COLLEVT_UDD1_
KEY
COLLEVT_UDD2_
KEY
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDDGEN1
UDDGEN2
UDDGEN3
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Collectible Process
Stores the collection process as well as overdue process information from the source system.
Properties
Property
Value
Target Table Name
CF_COLL_PROC
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_COLL_PROC
CI_OD_PROC
CI_SEV_PROC
CI_CUT_PROC
Stage Table Name
STG_CF_COLL_PROC
ODI Package Name
B1_PKG_CF_COLL_PROC
ETL View Name
B1_F_COLL_PROC_VW
B1_F_OD_PROC_VW
B1_COLLPROC_MON_MV1
B1_COLLPROC_MON_MV2
B1_COLLPROC_MON_TOPX_MV1
B1_COLLPROC_MON_TOPX_MV2
Fields
Source 1 - Collection Process (CI_COLL_PROC)
Target Field
OAS Field
Source Field
COLLPROC_KEY
Collectible Process Fact Surrogate Key
This field is populated with the sequence from SPL_COLL_PROC_SEQ.
SRC_COLLPROC_ID
CI_COLL_PROC.COLL_PROC_ID
ARRS_AT_START
Arrears at Start
CI_FT.TOT_AMT
This field is populated with the balance of all collection service agreements that are linked to the collection process, by using the collection arrears date and creation date of collection process as debit and credit dates.
ARRS_AT_END
Arrears at End
CI_FT.CUR_AMT
This is populated with a zero if collection process is active. Else, is populated with the balance of all active service agreements associated with collection process using Arrears Date and End Date of collection process as debit and credit dates.
ARRS_DIFF
Arrears at End - Arrears at Start
This field is populated with the difference between the arrears at start and arrears at end.
COLLPROC_DURATION
Collection Process Duration
This field is populated with the difference, in hours, between the end date and start date of the collection process.
COLL_PROC_SRC
Collection Process Source
This field is populated with ‘0’.
CURRENCY_ID
Currency Code
CI_COLL_PROC.CURRENCY_CD
ACCT_KEY
ADDR_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
This field is populated with mailing premise ID of the account. If not found, the characteristic premise ID of the service agreement is used.
COLLPROC_STAT_
KEY
Collectible Process Status Dimension Key
CI_COLL_PROC.COLL_STATUS_FLG
1. Set status as ‘Active’ when collection process is active or if collection process is completed and has a pending severance process.
2. ‘Effective’ when collection process has been canceled or completed, but all associated severance process are canceled.
3. ‘Ineffective’ if collection process is completed and atleast one severance process is completed or no severance processes are found.
COLL_TMPL_KEY
This field is populated with Collection Process Template Code prefixed with ‘C_’.
CEVT_TYPE_KEY
Collectible Event Type Dimension surrogate Key
This field is populated only if the collection process is in ‘Effective’ status.
Retrieve the event type of the last completed collection event that was successful in collecting the payment. If multiple events are completed at same time, use the one with highest sequence.
Prefix with ‘C_’ and use it.
START_DATE_KEY
CI_COLL_PROC.CRE_DTTM
END_DATE_KEY
CI_SEV_PROC.CRE_
DTTM
If the collection process status is ‘Active’, no end date would exist. Else, use the maximum severance event completion date. If it is not found, use the collection event completion date. If it is not found, use the creation date of the collection process.
PER_KEY
CI_ACCT_PER.PER_
ID
Set person ID = account’s main person ID
PREM_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
This field is populated with mailing premise ID of the account. If it is not found, the characteristic premise ID of the service agreement is used.
COLLPROC_UDD1_KEY
Collectible Process User Defined Dimension 1 Surrogate Key
COLLPROC_UDD2_KEY
Collectible Process User Defined Dimension 2 Surrogate Key
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDDGEN1
UDDGEN2
UDDGEN3
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Source 2 - Overdue Process (CI_OD_PROC)
Target Field
OAS Field
Source Field
COLLPROC_KEY
SEQ.
SRC_COLLPROC_ID
CI_OD_PROC. OD_PROC_ID
ARRS_AT_START
Arrears at Start
CI_FT.CUR_AMT
Retrieve the overdue bill associated with the overdue process using the Overdue Bill Characteristic Type defined on source and fetch the open item bill amounts.
For details, see the BI-Oriented Master Configuration in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
ARRS_AT_END
Arrears at End
This field is populated with the unpaid bill amount only when the status is not active. Else, it would be zero.
ARRS_DIFF
COLLPROC_DURATION
This field is populated with the difference, in hours, between the end date and start date of the overdue process.
COLL_PROC_SRC
This field is populated with ‘2’.
CURRENCY_ID
Currency Code
CI_OD_PROC.
CURRENCY_CD
ACCT_KEY
CI_OD_PROC.ACCT_
ID
ADDR_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
This field is populated with the mailing premise ID on the account. If it is not found, characteristic premise on the service agreement is used.
COLLPROC_STAT_
KEY
1. Set status as ‘Active’ when the overdue process status is ‘Active’ or the process is complete and at least one cut process is active.
2. Set status as ‘Effective’ if the overdue process has been canceled or is complete, and all associated cut processes are canceled.
3. Set status as ‘Ineffective’ if overdue process is complete, and either no cut processes are spawned or at least one of the cut process is complete.
COLL_TMPL_KEY
CI_OD_PROC.OD_PROC_TMP_CD
Prefix the overdue process template with ‘OD_’ and use it.
CEVT_TYPE_KEY
CI_OD_EVT.OD_EVT_TYP_CD
If the overdue process status is ‘Effective’, use the overdue event type of last completed overdue event. If multiple events have same completion date, pick the one with highest sequence and prefix it with 'OD_'.
START_DATE_KEY
CI_OD_PROC.CRE_DTTM
END_DATE_KEY
CI_OD_EVT.OD_EVT_STAT_DTTM
CI_OD_PROC.CRE_DTTM
1. If overdue process status flag is ‘Active’, the end date is null.
2. Else, use maximum cut event completion date. If it is not found, use the maximum overdue event collection date.
3. If it is still not found, use the creation date of overdue process.
PER_KEY
CI_ACCT_PER.PER_ID
PREM_KEY
CI_SA.CHAR_PREM_ID
This field is populated with the mailing premise ID on the account. If not found, the characteristic premise on the service agreement is used.
COLLPROC_UDD1_
KEY
COLLPROC_UDD2_
KEY
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDDGEN1
UDDGEN2
UDDGEN3
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
ENV_ID).
JOB_NBR
Job Number
Customer Contact
Stores the details of all customer contacts and their attributes.
Properties
Property
Value
Target Table Name
CF_CC
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_CC
Stage Table Name
STG_CF_CC
ODI Package Name
B1_PKG_CF_CC
ETL View Name
B1_F_CC_VW
B1_CC_HOU_MV1
B1_CC_MON_MV1
B1_CC_TOPX_MON_MV1
Fields
Target Field
OAS Field
Source Field
CC_KEY
Customer Contact Fact Key
This field is populated with the sequence from B1_CC_SEQ.
SRC_CC_ID
Customer Contact ID (Natural Key)
CI_CC.CC_ID
CURRENCY_CD
Currency Code
CI_ACCT.CURRENCY_CD
CC_DATE_KEY
Customer Contact Date (Date Dimension Surrogate Key)
CI_CC.CC_DTTM
This field extracts only the date from CI_CC.CC_DTTM.
CC_TIME_KEY
Customer Contact Time (Time Dimension Surrogate Key)
CI_CC.CC_DTTM
This field extracts only the time from CI_CC.CC_DTTM.
ACCT_KEY
CI_ACCT_PER.ACCT_
ID
The account is fetched using the person ID.
1. If one account is linked to the person, return this account.
2. If there are more than one accounts linked to the person:
a. Select the account linked to the non-closed and non-canceled service agreement with the latest start date where the person is linked as main person. If there is more than one account, return the first account.
b. If there are no non-canceled and non-closed service agreements linked to all of the accounts, return the first account.
ADDR_KEY
CI_SA.CHAR_PREM_
ID
Retrieve the first characteristic premise of the input account’s non-canceled and non-closed service agreement with the latest start date.
PER_KEY
CI_CC.PER_ID
PREM_KEY
CI_SA.CHAR_PREM_
ID
USER_KEY
CI_CC.USER_ID
CC_TYPE_KEY
Customer Contact Dimension Surrogate key
CI_CC.CC_TYPE_CD
CC_UDD1_KEY
Customer Contact User Defined Dimension 1 Surrogate Key
CC_UDD2_KEY
Customer Contact User Defined Dimension 2 Surrogate Key
FACT_CNT
Fact Count
This field is populated with the standard value of 1.
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDGEN_NUM1
UDDGEN_NUM2
UDDGEN_NUM3
UDDGEN_NUM4
UDDGEN_NUM5
UDDGEN_NUM6
UDDGEN_NUM7
UDDGEN_NUM8
UDDGEN_NUM9
UDDGEN_NUM10
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UD_DATE1
UD_DATE2
UD_DATE3
UD_DATE4
UD_DATE5
UD_DATE6
UD_DATE7
UD_DATE8
UD_DATE9
UD_DATE10
UD_DATE1_KEY
UD_DATE2_KEY
UD_DATE3_KEY
UD_DATE4_KEY
UD_DATE5_KEY
UD_DATE6_KEY
UD_DATE7_KEY
UD_DATE8_KEY
UD_DATE9_KEY
UD_DATE10_KEY
DATA_SOURCE_IND
CI_INSTALLATION.
ENV_ID
JOB_NBR
Job Number
Financial
Stores all frozen financial transactions defined in the source system.
ETL has the capability of excluding up to three adjustment types. These adjustment types need to be configured as part of the BI configuration in the source system.
For more details, see the BI-Oriented Master Configuration in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
Properties
Property
Value
Target Table Name
CF_FT
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_FT
Stage Table Name
STG_CF_FT
ODI Package Name
B1_PKG_CF_FT
ETL View Name
B1_F_FT_VW
B1_FT_MON_MV1
B1_FT_MON_TOPX_MV1
Fields
Target Field
OAS Field
Source Field
ACCT_KEY
CI_SA.ACCT_ID
ADDR_KEY
CI_SA.CHAR_PREM_ID
Use the characteristic premise ID from the service agreement. If it is not found, use the mailing premise ID from the account.
ADJ_TYPE_KEY
Adjustment type Dimension Surrogate Key
CI_FT.PARENT_ID
This field is populated when the financial transaction corresponds to adjustment/adjustment cancellation using the Parent ID column.
ARREARS_DT_KEY
Arrears Date (Date Dimension Surrogate Key)
CI_FT.ARS_DT
CURRENCY_CD
Currency Code
CI_FT.CURRENCY_
CD
CURR_AMT
Current Amount
CI_FT.CUR_AMT
FACT_CNT
Count
FISCAL_CAL_KEY
CI_GL_DIVISION.
CALENDER_ID
This field is populated using the calendar from GL division based on the accounting date.
FREEZE_DT_KEY
Freeze Date
CI_FT.FREEZE_DTTM
FT_KEY
Financial Fact Key
FT_TYPE_KEY
Financial Transaction Type Dimension Surrogate Key
CI_FT.FT_TYPE_FLG
FT_UDD1_KEY
Financial User Defined Dimension 1 Surrogate Key
FT_UDD2_KEY
Financial User Defined Dimension 2 Surrogate Key
OTHER_AMT
Other Amount
PAYOFF_AMT
Payoff Amount
CI_FT.TOT_AMT
PER_KEY
CI_ACCT_PER.PER_
ID
PREM_KEY
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
RATE_KEY
CI_BSEG_CALC.RS_
CD
This field is populated when a financial transaction is of type bill segment or bill segment cancellation. Rate Schedule Code from the bill segment calculation header is used.
REVENUE_AMT
Revenue Amount
CI_FT_GL.AMOUNT
This field is populated with the absolute value of the total amount of all financial transaction GLs whose distribution code’s characteristic type/ revenue characteristic value match with the characteristic type/value configured as part of the BI configuration in the source system and effective on the specific date.
SA_KEY
CI_FT.SA_ID
SIBLING_ID
Sibling ID (Natural Key)
CI_FT.SIBLING_ID
SRC_FT_ID
Financial Transaction ID (Natural Key)
CI_FT.FT_ID
TAX_AMT
Tax Amount
CI_FT_GL.AMOUNT
This field is populated with the absolute value of the total amount of all financial transaction GLs whose distribution code’s characteristic type/tax characteristic value match with the characteristic type/value configured as part of the BI configuration in the source system and effective on the specific date.
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDGEN_NUM1
UDDGEN_NUM2
UDDGEN_NUM3
UDDGEN_NUM4
UDDGEN_NUM5
UDDGEN_NUM6
UDDGEN_NUM7
UDDGEN_NUM8
UDDGEN_NUM9
UDDGEN_NUM10
UD_DATE1
UD_DATE2
UD_DATE3
UD_DATE4
UD_DATE5
UD_DATE6
UD_DATE7
UD_DATE8
UD_DATE9
UD_DATE10
UD_DATE1_KEY
UD_DATE2_KEY
UD_DATE3_KEY
UD_DATE4_KEY
UD_DATE5_KEY
UD_DATE6_KEY
UD_DATE7_KEY
UD_DATE8_KEY
UD_DATE9_KEY
UD_DATE10_KEY
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
USER_KEY
CI_FT.FREEZE_USER_ID
DATA_SOURCE_IND
JOB_NBR
Job Number
Financial General Ledger
Stores the financial transaction general ledger information, along with its attributes, defined in the source system.
Properties
Property
Value
Target Table Name
CF_FT_GL
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_FT_PROC
Stage Table Name
STG_CF_FT_GL
ODI Package Name
B1_PKG_CF_FT_GL
ETL View Name
B1_F_FT_GL_VW
Fields
Target Field
OAS Field
Source Field
FT_GL_KEY
Financial General Ledger Fact Key
This field is populated with the sequence from B1_FT_GL_SEQ.
SRC_FT_ID
CI_FT_GL.FT_ID
SRC_GL_SEQ_NBR
General Ledger Sequence Number (Natural Key)
CI_FT_GL.GL_SEQ_NBR
SIBLING_ID
Sibling ID
CI_FT.SIBLING_ID
ACCT_KEY
CI_SA.ACCT_ID
This field is populated with account information from the CI_SA table.
ADDR_KEY
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
This field is populated with the service agreement’s characteristic premise ID. If not found, it is populated with the account’s mailing premise ID.
PER_KEY
CI_ACCT_PER.PER_
ID
PREM_KEY
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
FREEZE_DT_KEY
Freeze Date (Date Dimension Surrogate Key)
CI_FT.FREEZE_DTTM
SA_KEY
CI_FT.SA_ID
USER_KEY
ADJ_TYPE_KEY
CI_FT.PARENT_ID
This field is populated when a financial transaction corresponds to adjustment/adjustment cancellation using the Parent ID column.
FT_TYPE_KEY
CI_FT.FT_TYPE_FLG
RATE_KEY
CI_BSEG_CALC.RS_
CD
This field is populated when a financial transaction is of type bill segment or bill segment cancellation. The Rate Schedule Code from bill segment calculation header is used.
FISCAL_CAL_KEY
CI_GL_DIVISION.
CALENDER_ID
GL_ACCT_KEY
GL Account Dimension Surrogate Key
CI_FT_GL.GL_ACCT
FT_GL_UDD1_KEY
FT GL User Defined Dimensions 1 Surrogate Key
FT_GL_UDD2_KEY
FACT_CNT
Count
CURRENCY_CD
Currency Code
CI_FT.CURRENCY_
CD
DEBIT_AMT
Debit Amount
CI_FT_GL.AMOUNT
All positive AMOUNT values
CREDIT_AMT
Credit Amount
CI_FT_GL.AMOUNT
All negative AMOUNT values
GL_AMT
General Ledger Amount
CI_FT_GL.AMOUNT
STATISTIC_AMT
Statistic Amount
CI_FT_GL.STATISTIC_AMT
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDGEN_NUM1
UDDGEN_NUM2
UDDGEN_NUM3
UDDGEN_NUM4
UDDGEN_NUM5
UDDGEN_NUM6
UDDGEN_NUM7
UDDGEN_NUM8
UDDGEN_NUM9
UDDGEN_NUM10
ARREARS_DT_KEY
CI_FT.ARS_DT
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UD_DATE1
UD_DATE2
UD_DATE3
UD_DATE4
UD_DATE5
UD_DATE6
UD_DATE7
UD_DATE8
UD_DATE9
UD_DATE10
UD_DATE1_KEY
UD_DATE2_KEY
UD_DATE3_KEY
UD_DATE4_KEY
UD_DATE5_KEY
UD_DATE6_KEY
UD_DATE7_KEY
UD_DATE8_KEY
UD_DATE9_KEY
UD_DATE10_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Order
Stores all enrollment orders that are defined in the source system. This fact stores the duration for completed orders.
Properties
Property
Value
Target Table Name
CF_ORDER
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_ENRL
Stage Table Name
STG_CF_ORDER
ODI Package Name
B1_PKG_CF_ORDER
ETL View Name
B1_F_ORDER_VW
Fields
Target Field
OAS Field
Source Field
ORDER_KEY
Order Fact Key
This field is populated with the sequence from B1_ORDER_SEQ.
SRC_ORDER_ID
Order ID (Natural Key)
CI_ENRL.ENRL_ID
CURRENCY_CD
Currency Code
CI_ACCT.CURRENCY_CD
B1_PROD_INSTANCE.CURRENCY_CD
If no account is associated with the Order, then the currency code available in the Product Instance metadata configuration will be populated.
DURATION
Duration
CI_ENRL_LOG.ENRL_LOG_DTTM
This field is populated with the difference in hours between the timestamp in the Order Creation log entry and the Order Completion/Cancellation log entry.
Note: This field is populated only if the order is complete or cancelled.
ACCT_KEY
CI_ENRL.ACCT_ID
ADDR_KEY
CI_ENRL.PREM_ID
CAMPAIGN_KEY
Campaign Dimension Surrogate Key
CI_ENRL.CAMPAIGN_CD
CREATE_DATE_KEY
This field is populated with the date in the Order Creation log entry.
END_DATE_KEY
This field is populated with the date in the Order Completion or Cancellation log entry.
ORDER_CAN_RSN_
KEY
Order Cancel Reason Dimension Surrogate Key
CI_ENRL.ENRL_CAN_RSN_CD
ORDER_STATUS_
KEY
Order Status Dimension Surrogate Key
CI_ENRL.ENRL_STATUS_FLG
PER_KEY
CI_ENRL.PER_ID
PKG_KEY
Package Dimension Surrogate Key
CI_ENRL.PACKAGE_ID
PREM_KEY
CI_ENRL.PREM_ID
START_DATE_KEY
CI_ENRL.START_DT
FACT_CNT
Fact Count
This field populates the standard value of “1”.
DATA_SOURCE_IND
JOB_NBR
Job Number
Pay Plan Accumulation
Stores all pay plans defined in the source system.
This fact is special in the sense that the ETL process setup to load this fact is configured as a daily refresh job. It is primarily to keep the measures updated to reflect on the current status.
The fact captures a variety of information about pay plans, such as the duration from the start, the number of days to go till the last payment, total payment amount, the amount paid so far, the number of future payments, etc.
Properties
Property
Value
Target Table Name
CF_PAY_PLAN
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_PP
Stage Table Name
STG_CF_PAY_PLAN
ODI Package Name
B1_PKG_CF_PAY_PLAN
ETL View Name
B1_F_PAY_PLAN_VW
B1_PAY_PLAN_MON_MV1
Fields
Target Field
OAS Field
Source Field
PAY_PLAN_KEY
Pay Plan Accumulation Fact Key
This field is populated with the sequence from B1_PAY_PLAN_ACCUM_SEQ.
SRC_PAY_PLAN_ID
Source Pay Plan ID
CI_PP.PP_ID
CURRENCY_CD
Currency Code
CI_ACCT.CURRENCY_CD
TOT_SCHED_PAY_AMT
Total Scheduled Payment Amount
CI_PP_SCHED_PAY.PP_SCHED_AMT
This field is populated with the sum of all scheduled payments for the respective pay plan ID.
DUR_FROM_START
Duration from Start
CI_PP.START_DT
CI_PP.LAST_STAT_DTTM
• If pay plan is “Active”: This field is populated with the difference (in hours) between the start date and the current date.
• If pay plan is “Canceled”, “Kept”, or “Broken”: This field is populated with the difference (in days) between the start date and the last status update date.
DAYS_TO_GO
Days to Go
CI_PP_SCHED_PAY.PP_SCHED_DT
This field is populated with the difference (in days) between the last scheduled payment and the current date.
Note: Populated for active pay plans only.
PAID_TO_DATE_AMT
Paid to Date
• If pay plan is “Active”. This field is populated with the sum of all past scheduled payments.
• If pay plan is “Kept”. This field is populated with the sum of all scheduled payments.
• If pay plan is “Canceled”. This field is populated with the sum of all scheduled payments before the end date.
• If pay plan is “Broken”: This field is populated with the sum of all scheduled payments before the scheduled payment closest to the end date.
NBR_TOT_SCHED_PAYMENTS
Total Scheduled Payments
CI_PP_SCHED_PAY.PP_ID,PP_SCHED_DT
This field is populated with the total number of scheduled payments.
NBR_FUTURE_SCHED_PAYMENTS
Future Scheduled Payments
This field is populated with the number of payments scheduled in the future.
Note: If the pay plan is “Broken”, this field includes the scheduled payment that lapsed and did not clear the payment.
TOTAL_FUTURE_PAY_AMT
Future Payment Amount
This field is populated with the sum of all payments scheduled in the future.
If the pay plan is “Broken/Canceled”, this field is populated with zero.
FUTURE_PAY_AMT_BUCKET1
Future Payment Amount Bucket 1
This field is populated with the sum of all future scheduled payments that fall into the age ranges configured for the bucket 1 slot for pay plans in the source system.
For details, see PP Future Payment Age Buckets in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
FUTURE_PAY_AMT_BUCKET2
Future Payment Amount Bucket 2
See the FUTURE_PAY_AMT_BUCKET1 field for transformation logic.
FUTURE_PAY_AMT_BUCKET3
Future Payment Amount Bucket 3
FUTURE_PAY_AMT_BUCKET4
Future Payment Amount Bucket 4
FUTURE_PAY_AMT_BUCKET5
Future Payment Amount Bucket 5
FUTURE_PAY_AMT_BUCKET6
Future Payment Amount Bucket 6
FUTURE_PAY_AMT_BUCKET7
Future Payment Amount Bucket 7
FUTURE_PAY_AMT_BUCKET8
Future Payment Amount Bucket 8
FUTURE_PAY_AMT_BUCKET9
Future Payment Amount Bucket 9
FUTURE_PAY_AMT_BUCKET10
Future Payment Amount Bucket 10
START_DTTM
Start Date/Time
CI_PP.START_DT
END_DTTM
End Date/Time
This field is populated only when the pay plan status is “Canceled”, “Broken”, or “Kept”.
START_DATE_KEY
Start Date (Date Dimension Surrogate) Key
CI_PP.START_DT
START_TIME_KEY
Start Time (Time Dimension Surrogate) Key
CI_PP.START_DT
END_DATE_KEY
End Date (Date Dimension Surrogate) Key
END_TIME_KEY
End Time (Time Dimension Surrogate) Key
PAY_PLAN_STATUS_KEY
Pay Plan Status Dimension Surrogate Key
CI_PP.PP_STAT_FLG
PAY_PLAN_TYPE_
KEY
Pay Plan Type Dimension Surrogate Key
CI_PP.PP_TYPE_CD
PAY_METHOD_KEY
Pay Method Dimension Surrogate Key
CI_PP.PAY_METH_CD
PER_KEY
CI_ACCT_PER.PER_
ID
The main customer of the account associated with the pay plan is used to populate this field.
ACCT_KEY
CI_PP.ACCT_ID
PAYOR_ACCT_KEY
Payor Account (Account Dimension Surrogate) Key
CI_PP.PAYOR_ACCT_
ID
PREM_KEY
CI_ACCT.MAILING_
PREM_ID
ADDR_KEY
CI_ACCT.MAILING_
PREM_ID
PAY_PLAN_UDD1_
KEY
Pay Plan User Defined Dimension 1 Surrogate Key
PAY_PLAN_UDD2_
KEY
Pay Plan User Defined Dimension 2 Surrogate Key
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Note: The Future Payment Age buckets configured in the source are loaded in the MDADM.B1_RANGE_LOOKUP table in the data warehouse. The ELT job for this is configured to be initial load only. Any incremental changes to these buckets after the initial data load will not be reflected in the warehouse. However, if there arises a need to reconfigure the buckets, then data should be truncated and reloaded in the fact table and the range lookup table to reflect the changes.
For details about Range look-up and reloading the data, see the Data Reload section in Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
Pay Plan Snapshot
Provides a snapshot of the pay plans defined in the source system. Once a pay plan reaches its final state (Kept, Canceled, or Broken), it will no longer be included in the snapshots of the further periods.
This fact captures a variety of information about pay plans, such as the duration from the start, the number of days to go till the last payment, total payment amount, the amount paid so far, the number of future payments, etc.
Properties
Property
Value
Target Table Name
CF_PAY_PLAN_SNAP
Table Type
Fact
Fact Type
Snapshot
Driver Table
CI_PP
Stage Table Name
STG_CF_PAY_PLAN_SNAP
ODI Package Name
B1_PKG_CF_PAY_PLAN_SNAP
ETL View Name
n/a
B1_PAY_PLAN_SNAP_MON_MV1
B1_PAY_PLAN_SNP_MON_TOPX_MV1
Fields
Target Field
OAS Field
Source Field
PAY_PLAN_SNAP_
KEY
Pay Plan Snapshot Fact Key
This field is populated with the sequence from B1_PAY_PLAN_SNAP_SEQ.
SRC_PAY_PLAN_ID
Source Pay Plan ID
CI_PP.PP_ID
CURRENCY_CD
Currency Code
CI_ACCT.CURRENCY_CD
TOT_SCHED_PAY_
AMT
This field is populated with the sum of all scheduled payments for that pay plan ID.
DUR_FROM_START
Duration from Start
CI_PP.START_DT
• If pay plan is “Active”: This field is populated with the difference (in days) between the start date and the current date.
DAYS_TO_GO
Days to Go
This field is populated with the difference (in days) between the last scheduled payment and the snapshot end date.
PAID_TO_DATE_AMT
Paid to Date
NBR_TOT_SCHED_
PAYMENTS
NBR_FUTURE_
SCHED_PAYMENTS
If the pay plan is Broken/Canceled, this field is populated with zero.
FUTURE_PAY_AMT_
BUCKET1
FUTURE_PAY_AMT_
BUCKET2
FUTURE_PAY_AMT_
BUCKET3
FUTURE_PAY_AMT_
BUCKET4
FUTURE_PAY_AMT_
BUCKET5
FUTURE_PAY_AMT_
BUCKET6
FUTURE_PAY_AMT_
BUCKET7
FUTURE_PAY_AMT_
BUCKET8
FUTURE_PAY_AMT_
BUCKET9
FUTURE_PAY_AMT_
BUCKET10
START_DTTM
Start Date/Time
CI_PP.START_DT
END_DTTM
End Date/Time
SNAP_TYPE_CD
Snap Type Code
This field is populated with 'M'(Monthly) or 'W'(Weekly) based on the configuration of the ETL process for this snapshot fact.
SNAPSHOT_DT
Snapshot Date
This field is populated with the last date of the current snapshot period.
SNAPSHOT_DATE_
KEY
Snapshot Date (Date Dimension Surrogate) Key
START_DATE_KEY
CI_PP.START_DT
START_TIME_KEY
CI_PP.START_DT
END_DATE_KEY
CI_PP.LAST_STAT_
DTTM
END_TIME_KEY
CI_PP.LAST_STAT_
DTTM
PAY_PLAN_STATUS_KEY
CI_PP.PP_STAT_FLG
PAY_PLAN_TYPE_
KEY
CI_PP.PP_TYPE_CD
PAY_METHOD_KEY
CI_PP.PAY_METH_CD
PER_KEY
CI_ACCT_PER.PER_
ID
This field is populated with the main customer of the account associated with the pay plan.
ACCT_KEY
CI_PP.ACCT_ID
PAYOR_ACCT_KEY
CI_PP.PAYOR_ACCT_
ID
PREM_KEY
CI_ACCT.MAILING_
PREM_ID
ADDR_KEY
CI_ACCT.MAILING_
PREM_ID
PAY_PLAN_SNAP_UDD1_KEY
PAY_PLAN_SNAP_UDD2_KEY
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Payment Arrangement Accumulation
Stores all payment arrangements (excluding those in pending start state) in the source system.
The fact is special in the sense that the ETL process setup to load this fact will be configured as a daily refresh job. It is to primarily keep the measures updated to reflect the current status.
Properties
Property
Value
Target Table Name
CF_PA
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_SA
Stage Table Name
STG_CF_PA
ODI Package Name
B1_PKG_CF_PA
ETL View Name
B1_F_PA_VW
B1_PA_MV1
Fields
Target Field
OAS Field
Source Field
PA_KEY
Payment Arrangement Accumulation Fact Key
This field is populated with the sequence from B1_PA_ACCUM_SEQ.
SRC_SA_ID
Source Service Agreement ID
CI_SA.SA_ID
CURRENCY_CD
Currency Code
CI_SA.CURRENCY_CD
REC_CHARGE_AMT
CI_SA_RCHG_HIST.RCR_CHG_AMT
This field is populated with the recurring charge amount effective as of the sysdate.
TOTAL_PA_AMT
Total Payment Arrangement Amount
CI_ADJ.ADJ_AMT
This field is populated with the adjustment amount for adjustment(s) used to transfer the original service agreement’s balance.
• If the payment arrangement is “active” or “kept”, then all non-canceled xfer adjustments are contributed to the arrangement amount.
• If the payment arrangement is “canceled”, all canceled xfer adjustments are contributed to the arrangement amount.
• If the payment arrangement is “broken”, then all canceled xfer adjustments are contributed to the arrangement amount.
INSTALLMENT_CNT
Total Number of Installments
This field is calculated as the total payment arrangement amount divided by the recurring charge amount.
DUR_FROM_START
Duration from Start
CI_SA.START_DT
CI_SA.END_DT
If the payment arrangement’s service agreement has an end date, this field populates the difference between start date and end date. Else, it populates the difference between start date and current date.
PAID_TO_DATE_AMT
Paid to Date Amount
CI_FT.CUR_AMT
This field is populated with the sum of all payments made against the pay arrangement service agreement.
FUTURE_PAY_AMT
Future payment amount is set to zero when the payment arrangement is in Broken/Canceled state. Else, it is the difference between total pay agreement amount and paid to date columns.
FUTURE_PAY_AMT_
BUCKET1
This field is populated with the sum of all future scheduled payments that fall into the age ranges configured for the bucket 1 slot for payment arrangements in the source system.
Future scheduled payments are identified based on the remaining amount, billing frequency, and bill cycle schedule.
For details, see PA Future Payment Age Buckets in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
FUTURE_PAY_AMT_
BUCKET2
FUTURE_PAY_AMT_
BUCKET3
FUTURE_PAY_AMT_
BUCKET4
FUTURE_PAY_AMT_
BUCKET5
FUTURE_PAY_AMT_
BUCKET6
FUTURE_PAY_AMT_
BUCKET7
FUTURE_PAY_AMT_
BUCKET8
FUTURE_PAY_AMT_
BUCKET9
FUTURE_PAY_AMT_
BUCKET10
START_DTTM
Start Date/Time
CI_SA.START_DT
END_DTTM
End Date/Time
CI_SA.END_DT
START_DATE_KEY
CI_SA.START_DT
START_TIME_KEY
CI_SA.START_DT
END_DATE_KEY
CI_SA.END_DT
END_TIME_KEY
CI_SA.END_DT
PA_STATUS_KEY
Payment Arrangement Status Dimension Surrogate Key
CI_SA.SA_STATUS_FLG
1. Set status as ‘Active’ if the service agreement’s status is ‘Active’, ‘Pending Stop’, ‘Stopped’, or ‘Reactivated’.
2. ‘Broken’ if the service agreement’s status is ‘Closed’ with a broken payment arrangement characteristic.
3. Kept if the service agreement’s status is ‘Closed’ without the broken payment arrangement characteristic. (Broken characteristic type/value is defined as a parameter on source.
For more details on the parameters, see BI-Oriented Master Configuration in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
4. ‘Canceled’ if the service agreement is canceled.
INSTALLMENT_CNT_KEY
Installments Count Dimension Surrogate Key
This field populates the appropriate key using the installment amount and age ranges from the Installment Count dimension.
For details, see PA Number of Installments Buckets in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
REC_CHARGE_AMOUNT_KEY
Recurring Charge Bucket Dimension Surrogate Key
CI_SA_RCHG_HIST.
RCR_CHG_AMT
This field populates the appropriate key using the recurring charge amount and age ranges from the Recurring Charge Amount Bucket dimension.
The recurring charge amount age ranges are defined on the source.
For details, see PA Recurring Charge Amount Buckets in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
PER_KEY
CI_ACCT_PER.PER_
ID
This field populates the person ID with the main customer of the account
ACCT_KEY
CI_SA.ACCT_ID
SA_KEY
CI_SA.SA_ID
PREM_KEY
CI_ACCT.MAILING_
PREM_ID
ADDR_KEY
CI_ACCT.MAILING_
PREM_ID
PA_UDD1_KEY
Payment Arrangement User Defined Dimension 1 Surrogate Key
PA_UDD2_KEY
Payment Arrangement User Defined Dimension 2 Surrogate Key
FACT_CNT
Fact Count
This field is populated with a standard value of “1”.
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Payment Arrangement Snapshot
Stores snapshots of all payment arrangements that started before the snapshot date and excludes the service agreements of pending start, canceled, and incomplete statuses. The snapshot also excludes closed service agreements where the difference (in days) between the snapshot end date and the service agreement end date is greater than the 'X' number of days to exclude closed service agreements.
The value 'X' will have to be configured as part of the BI configuration in the source system.
Properties
Property
Value
Target Table Name
CF_PA_SNAP
Table Type
Fact
Fact Type
Snapshot
Driver Table
CI_SA
Stage Table Name
STG_CF_PA_SNAP
ODI Package Name
B1_PKG_CF_PA_SNAP
ETL View Name
B1_F_PA_SNAP_VW
B1_PA_SNAP_MON_MV1
B1_PA_SNAP_MON_TOPX_MV1
Fields
Target Field
OAS Field
Source Field
PA_SNAP_KEY
Payment Arrangement Snapshot Fact Key
This field is populated with the sequence from B1_PA_SNAP_SEQ.
SRC_SA_ID
CI_SA.SA_ID
CURRENCY_CD
Currency Code
CI_SA.CURRENCY_
CD
REC_CHARGE_AMT
CI_SA_RCHG_HIST.
RCR_CHG_AMT
This field is populated with the recurring charge amount effective as of the snapshot date.
TOTAL_PA_AMT
CI_ADJ.ADJ_AMT
This field is populated with the adjustment amount for the adjustment(s) used to transfer the original service agreement’s balance.
• If the payment arrangement is still “active” or “kept”, then all non-canceled xfer adjustments are contributed to the arrangement amount.
INSTALLMENT_CNT
This field is populated with the value calculated by dividing the total payment arrangement amount by recurring charge amount.
DUR_FROM_START
Duration from Start
CI_SA.START_DT
CI_SA.END_DT
If the pay arrangement service agreement has an end date, this field is populated with the difference between start date and end date.
PAID_TO_DATE_AMT
Paid to Date Amount
CI_FT.CUR_AMT
FUTURE_PAY_AMT
The future payment amount is set to zero when the payment arrangement is in Broken/Canceled states. Else, it is the difference between the Total PA Amount and Paid To Date columns.
START_DTTM
Start Date/Time
CI_SA.START_DT
END_DTTM
End Date/Time
CI_SA.END_DT
SNAP_TYPE_CD
Snap Type Code
SNAPSHOT_DT
Snapshot Date
SNAPSHOT_DATE_
KEY
START_DATE_KEY
CI_SA.START_DT
START_TIME_KEY
CI_SA.START_DT
END_DATE_KEY
CI_SA.END_DT
END_TIME_KEY
CI_SA.END_DT
PA_STATUS_KEY
CI_SA.SA_STATUS_
FLG
For more details, see BI-Oriented Master Configuration in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
5. ‘Active’ if the service agreement is closed and the service agreement start date is before the snapshot date, but the end date is after the snapshot date.
INSTALLMENT_CNT_KEY
Based on the installment amount and the age ranges, the dimension key has to be identified.
The installment count age ranges are defined on the source.
CI_SA_RCHG_HIST.
RCR_CHG_AMT
This field is populated with the recurring charge amount and age ranges from the Recurring Charge Amount bucket dimension.
PER_KEY
CI_ACCT_PER.PER_
ID
ACCT_KEY
CI_SA.ACCT_ID
SA_KEY
CI_SA.SA_ID
PREM_KEY
CI_ACCT.MAILING_
PREM_ID
ADDR_KEY
CI_ACCT.MAILING_
PREM_ID
PA_SNAP_UDD1_KEY
PA_SNAP_UDD2_KEY
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Payment Tender
Stores all pay tenders defined in the source system.
The ETL process for this fact is special in the sense that it considers ‘deletes’ in the source system. If a pay tender is deleted in the source system, it will also be deleted from the fact table. This fact stores the tender amount information.
Properties
Property
Value
Target Table Name
CF_PAY_TNDR
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_PAY_TNDR
Stage Table Name
STG_CF_PAY_TNDR
ODI Package Name
B1_PKG_CF_PAY_TNDR
ETL View Name
B1_F_PAY_TNDR_VW
Fields
Target Field
OAS Field
Source Field
PAY_TNDR_KEY
Payment Tender Fact Key
This field is populated with the sequence from SPL_PAY_TNDR_SEQ.
SRC_PAY_TENDER_
ID
Payment Tender ID (Natural Key)
CI_PAY_TNDR.PAY_
TENDER_ID
CURRENCY_CD
Currency Code
CI_PAY_TNDR.CURRENCY_CD
TNDR_CTRL_ID
Tender Control ID
CI_PAY_TNDR.TNDR_CTL_ID
TNDR_AMT
Tender Amount
CI_PAY_TNDR.TENDER_AMT
CANCEL_DATE_KEY
CI_FT.FREEZE_DTTM
CI_PAY_EVENT.CRE_DTTM
This field is populated only when the pay tender has been canceled. The freeze date on the pay segment cancellation FT will be used. Otherwise, the pay event's creation date will be used.
PAYEVT_DATE_KEY
CI_PAY_EVENT.PAY_DT
TNDR_CTRL_DATE_KEY
CI_TNDR_CTL.CRE_DTTM
Only the date portion from the source field will be used.
TNDR_STATUS_KEY
Tender Status Dimension Surrogate Key
CI_PAY_TNDR.TNDR_STATUS_FLG
TNDR_TYPE_KEY
Tender Type Dimension Surrogate Key
CI_PAY_TNDR.TENDER_TYPE_CD
TNDR_SRCE_KEY
Tender Source Dimension Surrogate Key
CI_TNDR_CTL.TNDR_SOURCE_CD
ACCT_KEY
CI_PAY_TNDR.PAYOR_ACCT_ID
ADDR_KEY
CI_SA.CHAR_PREM_
ID
This field is populated with the characteristic premise of the payer account’s non-cancelled and non-closed service agreement with latest start date.
PER_KEY
CI_ACCT_PER.PER_
ID
The main customer of the payor account will be used to populate this field.
PREM_KEY
CI_SA.CHAR_PREM_
ID
PAY_CAN_RSN_KEY
Payment Cancel Reason Dimension Surrogate Key
CI_PAY_TNDR.CAN_
RSN_CD
PAY_TNDR_UDD1_
KEY
Payment Tender User Defined Dimension 1 Surrogate Key
PAY_TNDR_UDD2_
KEY
Payment Tender User Defined Dimension 2 Surrogate Key
FACT_CNT
Fact Count
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
UDDGENL7
UDDGENL8
UDDGENL9
UDDGENL10
UDDGEN_NUM1
UDDGEN_NUM2
UDDGEN_NUM3
UDDGEN_NUM4
UDDGEN_NUM5
UDDGEN_NUM6
UDDGEN_NUM7
UDDGEN_NUM8
UDDGEN_NUM9
UDDGEN_NUM10
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK6_KEY
UDDFK7_KEY
UDDFK8_KEY
UDDFK9_KEY
UDDFK10_KEY
UD_DATE1
UD_DATE2
UD_DATE3
UD_DATE4
UD_DATE5
UD_DATE6
UD_DATE7
UD_DATE8
UD_DATE9
UD_DATE10
UD_DATE1_KEY
UD_DATE2_KEY
UD_DATE3_KEY
UD_DATE4_KEY
UD_DATE5_KEY
UD_DATE6_KEY
UD_DATE7_KEY
UD_DATE8_KEY
UD_DATE9_KEY
UD_DATE10_KEY
DATA_SOURCE_IND
JOB_NBR
Job Number
Service Agreement Arrears Snapshot
Stores the snapshots of all non-canceled service agreements that started before the snapshot date. The snapshot also excludes the closed service agreements where the difference (in days) between the snapshot end date and the service agreement end date is greater than the 'X' number of days to exclude the closed service agreements. The value 'X' should be configured as part of the BI configuration in the source system.
Note that only UDM1 to UDM10 fields are used to populate the bucketized arrears information. If more than 10 age buckets are configured in Oracle Utilities Customer Care and Billing for arrears, only the first 10 buckets will be considered by the out-of-the-box ETL. If the arrears amount need to be bucketized into more than 10 buckets, customize it to populate the remaining arrears bucket columns.
For details, see BI-Oriented Master Configuration in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
Entity Relationship Diagram
Properties
Property
Value
Target Table Name
CF_ARREARS
Table Type
Fact
Fact Type
Snapshot
Driver Table
CI_SA
Stage Table Name
STG_CF_ARREARS
ODI Package Name
B1_PKG_CF_ARREARS
ETL View Name
B1_F_ARREARS_VW
Materialized View Name
B1_ARREARS_MON_MV1
B1_ARREARS_MON_TOPX_MV1
Fields
Target Field
OAS Field
Source Field
ACCT_KEY
CI_SA.ACCT_ID
ADDR_KEY
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
ARREARS_KEY
Arrears Fact Generated Key
This field is populated with the sequence from B1_ARREARS_SEQ.
CURRENCY_CD
Currency Code
CI_SA.CURRENCY_
CD
CURR_BAL_AMT
Current Balance
CI_FT.CUR_AMT
DATE_KEY
This field is populated with the snapshot date.
FISCAL_CAL_KEY
CI_CAL_PERIOD.CALENDER_ID
This field is populated using the calendar based on accounting date.
PAYOFF_BAL_AMT
Payoff Balance Amount
CI_FT.TOT_AMT
PER_KEY
CI_ACCT_PER.PER_
ID
PREM_KEY
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
This field is populated with the Char Prem ID. If not found, it is populated with the mailing premise ID from account.
SA_KEY
CI_SA.SA_ID
SNAP_TYPE_CD
Snap Type
UDM1
The arrears date and arrears amounts are identified by fetching the debits and credits. Amounts are summed and put in the UDM columns based on the age ranges. These age ranges are defined on the source.
For details, see SA Arrears Buckets in the Configuring Oracle Utilities Analytics Warehouse chapter in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
UDM2
See the UDM1 field for transformation logic.
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDM21
User Defined Measure 21
UDM22
User Defined Measure 22
UDM23
User Defined Measure 23
UDM24
User Defined Measure 24
UDM25
User Defined Measure 25
UDM26
User Defined Measure 26
UDM27
User Defined Measure 27
UDM28
User Defined Measure 28
UDM29
User Defined Measure 29
UDM30
User Defined Measure 30
FACT_CNT
Fact Count
RATE_KEY
Rate dimension surrogate key
CI_SA_RS_HIST.RS_
CD
This field uses the Rate Code from service agreement rate history based on the effective date.
UDDGEN1
UDDGEN2
UDDGEN3
ARREARS_UDD1_
KEY
Arrears User Defined Dimension 1 Surrogate Key
ARREARS_UDD2_
KEY
Arrears User Defined Dimension 2 Surrogate Key
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
SRC_SA_ID
SA Identifier
CI_SA.SA_ID
SNAPSHOT_DT
Snapshot Date
DAYS_LAST_FRZ_BS
Number of Days Since Last Frozen BS
CI_BSEG.END_DT
This field is populated with the difference (in days) between the freeze date of the last frozen bill segment for the service agreement and the snapshot end date.
Note: If there is no frozen bill segment for the service agreement, use the service agreement start date.
DAYS_LAST_FRZ_BS_KEY
Days Since Last Frozen Dimension Surrogate Key
Based on the measure retrieved above, fetch the corresponding dimension key.
DAYS_UNBILLED_
USG
Number of Days of Unbilled Usage
CI_BSEG.END_DT
CI_SA.END_DT
1. If there is a frozen bill segment:
a. If the service agreement has ended (Status 60), use the difference between the agreement end date and the end date of bill segment latest before the snapshot date.
b. Else, use the difference between the snapshot date and the end date of bill segment latest before the snapshot date.
2. If there is no frozen bill segment:
a. If the service agreement has ended (Status 60), use the difference between agreement’s end date and start date.
b. Else, use the difference between the snapshot date and the service agreement’s start date.
DAYS_UNBILLED_
USG_KEY
Days of Unbilled Usage Dimension Surrogate Key
DATA_SOURCE_IND
JOB_NBR
Job Number
Note: The Arrears Age buckets configured in the source are loaded in the MDADM.B1_RANGE_LOOKUP table in the data warehouse. The ELT job for this is configured to be initial load only. Any incremental changes to these buckets after the initial data load will not be reflected in the warehouse. However, if there arises a need to reconfigure the buckets, then data should be truncated and reloaded in the fact table and the range lookup table to reflect the changes.
Service Agreement Billing
Stores the details of the service agreements eligible for billing in a bill window based on the bill segment creation. Information related to the latest bill segment for a service agreement, bill cycle, and window start date combination is stored in this fact. Manual bills are excluded from this fact.
Properties
Property
Value
Target Table Name
CF_SA_BILLING
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_BSEG
Stage Table Name
STG_CF_SA_BILLING
ODI Package Name
B1_PKG_CF_SA_BILLING
ETL View Name
B1_F_SA_BILLING_VW
B1_SA_BILLING_MON_MV1
B1_SA_BILLING_MON_TOPX_MV1
Fields
Target Field
OAS Field
Source Field
SA_BILLING_KEY
SA Billing Fact Key
This field is populated with the sequence from B1_SA_BILLING_ACCUM_SEQ.
SRC_SA_ID
CI_BSEG.SA_ID
SRC_BILL_CYC_CD
Bill Cycle Code
CI_BSEG.BILL_CYC_
CD
If a bill segment does not have a bill cycle, it is retrieved from the bill.
WIN_START_DTTM
Window Start Date/Time
CI_BSEG.WIN_START_DT
CI_BILL.WIN_START_DT
If a bill segment does not have a window start date populated, it is fetched from the bill.
FROZEN_DUR
Duration to Frozen
CI_BILL.CRE_DTTM
CI_FT.
FREEZE_DTTM
This field is populated with the difference (in hours) between the bill’s creation date and the bill segment freeze date.
REBILL_IND
Re-billed Indicator
CI_BSEG.REBILL_
SEG_ID
This field is populated with “1” if the latest bill segment for the service agreement is a re-bill. Else, “0”.
ORIG_REV_AMT
Original Revenue Amount
CI_FT_GL.AMOUNT
This field is populated with the revenue amount of the original bill segment if the current bill segment being processed is a re-billed one.
REV_AMT
Revenue Amount
CI_FT_GL.AMOUNT
This field is populated with the absolute value of total amount of all financial transaction GLs whose distribution code’s characteristic type/ revenue characteristic value match with the characteristic type/value configured as part of the BI configuration in the source system and ‘Effective’ on the specific date.
CURRENCY_CD
Currency Code
CI_FT.CURRENCY_
CD
FIRST_BS_IND
First Bill Segment of SA Indicator
CI_SA.START_DT
CI_BSEG.START_DT
This field is set to 1 if the service agreement start date matches with the bill segment start date. Else, it is set to zero.
EST_IND
Estimated Indicator
CI_BSEG.EST_SW
This field is populated with “1” if the latest bill segment is an estimate. Else, “0”.
HIGH_BILL_CASE_
IND
High Bill Complaint Indicator
Set the indicator to 1 if all the below conditions return true:
1. If there exists a case with Case Characteristic Value same as bill ID of the bill segment being processed. Characteristic type corresponding to the bill would be defined on the source system extract parameters.
2. The above case should be of Case type corresponding to High Bill Complaint. These Case types are again provided by users on the source system extract parameters.
3. Case should not be in a status same as the ‘Exclusion’ status mentioned on source system extract parameters.
For more information on these parameters that have to be configured on source, see BI-Oriented Master Configuration in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
FREEZE_DTTM
Freeze Date/Time
CI_FT.FREEZE_DTTM
CRE_DTTM
Creation Date/Time
CI_BILL.CRE_DTTM
BILL_CYC_SCH_KEY
Bill Cycle Schedule Dimension Surrogate Key
CI_BSEG.BILL_CYC_CD + WIN_START_DT
CI_BILL.BILL_CYC_CD + WIN_START_DT
If the bill segment does not have information, it is fetched from the bill.
BSEG_STATUS_KEY
Bill Segment Status Dimension Surrogate Key
CI_BSEG.BSEG_STAT_FLG
1. Use the actual status if bill segment is not in error or deleted.
2. If status is ‘Error’, look for the error message. If error displayed is “Awaiting Bill Determinants from MDM”, use the ‘Awaiting BD’ status.
3. When the bill segment is deleted, use the ‘Deleted’ status.
BILL_CAN_RSN_KEY
Bill Cancel Reason Dimension Surrogate Key
CI_BSEG.CAN_RSN_
CD
The Bill Cancel Reason value should be populated only if the service agreement’s bill segment is pending cancel or canceled. If the latest bill segment is a Rebill bill segment, the cancel reason should be on the older BS.
MSG_KEY
Message Dimension Surrogate Key
CI_BSEG_EXCP.MESSAGE_CAT_NBR
CI_BSEG_EXCP.MESSAGE_NBR
BILL_DAY_IN_WIN_KEY
Day In Window Dimension Surrogate Key
CI_FT.FREEZE_DTTM
CI_BILL_CYC_SCH.FREEZE_DTTM
This logic is applicable for bill segments with ‘Frozen’ status.
If the freeze date is between the bill cycle schedule start and end dates, set 'In Window', else 'Outside Window'. The billing day in window can be calculated as difference between the freeze date and the window start date. Based on this difference, suitable age range needs to be identified.
These age ranges are configured on source. For details, see Billing Day In Window Buckets in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
DAYS_TO_WIN_CLS_KEY
Days to Window Closure Dimension Surrogate Key
CI_BILL_CYC_SCH.WIN_END_DT
This field is populated only if the latest bill segment for the service agreement is in status Error/Deleted/Awaiting BD. This is the difference between the window end date and current date. If the window end date is greater than sysdate, pick the range from open window age configuration. Else, pick the one from closed window age configurations, which are defined on source.
For details, see Days Before Bill Window Closes Buckets in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
MSRMT_TYPE_KEY
Measurement Type Dimension Surrogate Key
C1-USAGE.USG_DATA_AREA
To determine the Measurement Type, check Special Role flag on SA Type.
1. If it’s “Bill Determinants Required”, check if there’s a Usage Request for the service agreement’s latest bill segment and determine the measurement type based on the usage request list (each entry in the list has a ‘usage type” associated with it).
2. If it’s “Interval”, set measurement type to “Interval”.
3. If it’s any other special role flag value (billable charge, deposit, PA, etc), set measurement type to “N/A”.
4. If it’s blank, check the valid SP Types linked to the SA Type and see if any have a subtype of “Meter”. If yes, set measurement type to “Scalar”. Otherwise, set to “N/A”.
FREEZE_DATE_KEY
Freeze Date (Date Dimension Surrogate) Key
CI_FT.FREEZE_DTTM
FREEZE_TIME_KEY
Freeze Time (Time Dimension Surrogate) Key
CI_FT.FREEZE_DTTM
CRE_DATE_KEY
Creation Date (Date Dimension Surrogate) Key
CI_BILL.CRE_DTTM
CRE_TIME_KEY
Creation Time (Time Dimension Surrogate) Key
CI_BILL.CRE_DTTM
WIN_START_DATE_KEY
Window Start Date (Date Dimension Surrogate) Key
WIN_START_TIME_KEY
Window Start Time (Time Dimension Surrogate) Key
ACCT_KEY
CI_SA.ACCT_ID
ADDR_KEY
Address Dimension Surrogate Key
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
If the characteristic premise is not found, use the mailing premise from account.
PER_KEY
Person Dimension Surrogate Key
CI_ACCT_PER.PER_
ID
The field is populated with the main customer of the account.
PREM_KEY
Premise Dimension Surrogate Key
CI_SA.CHAR_PREM_
ID
CI_ACCT.MAILING_
PREM_ID
SA_KEY
Service Agreement Dimension Surrogate Key
CI_BSEG.SA_ID
RATE1_KEY
Rate Dimension Surrogate Key
CI_SA_RS_HIST.RS_
CD
CI_BSEG_CALC.RS_
CD
If the bill segment has no calculation header, retrieve the rate effective on the service agreement as of the bill segment start date.
If bill segment has calculation headers, pick the first two distinct primary rate schedules and store these in two columns.
RATE2_KEY
CI_SA_RS_HIST.RS_CD
CI_BSEG_CALC.RS_CD
See RATE1_KEY description for logic details.
SA_BILLING_UDD1_KEY
SA Billing User Defined Dimension 1 Surrogate Key
SA_BILLING_UDD2_KEY
SA Billing User Defined Dimension 2 Surrogate Key
FACT_CNT
Fact Count
UDM1
User Defined Measure 1
UDM2
UDM3
UDM4
User Defined Measure 4
UDM5
User Defined Measure 5
UDM6
User Defined Measure 6
UDM7
User Defined Measure 7
UDM8
User Defined Measure 8
UDM9
User Defined Measure 9
UDM10
User Defined Measure 10
UDDGEN1
User Defined Degenerate Dimension 1
UDDGEN2
User Defined Degenerate Dimension 2
UDDGEN3
User Defined Degenerate Dimension 3
UDDGEN4
User Defined Degenerate Dimension 4
UDDGEN5
User Defined Degenerate Dimension 5
UDDGENL1
User Defined Long Degenerate Dimension 1
UDDGENL2
User Defined Long Degenerate Dimension 2
UDDGENL3
User Defined Long Degenerate Dimension 3
UDDGENL4
User Defined Long Degenerate Dimension 4
UDDGENL5
User Defined Long Degenerate Dimension 5
UDDFK1_KEY
User Defined Dimension Foreign Key 1
UDDFK2_KEY
User Defined Dimension Foreign Key 2
UDDFK3_KEY
User Defined Dimension Foreign Key 3
UDDFK4_KEY
User Defined Dimension Foreign Key 4
UDDFK5_KEY
User Defined Dimension Foreign Key 5
DATA_SOURCE_IND
Data Source Indicator
B1_PROD_INSTANCE.DSI
This field is populated with the DSI value on the source product instance configuration. This table is populated as part of the initial setup and the DSI value is extracted from the environment ID of the source system (CI_INSTALLATION.ENV_ID).
JOB_NBR
Job Number
This field is populated with the ODI job execution session number.
Service Agreement
Stores all service agreements defined in the source system.
Properties
Property
Value
Target Table Name
CF_SA
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_SA
Stage Table Name
STG_CF_SA
ODI Package Name
B1_PKG_CF_SA
ETL View Name
B1_F_SA_VW
B1_SA_TOPX_MON_MV1
B1_SA_TOPX_MON_MV2
B1_SA_MON_MV1
B1_SA_MON_MV2
Fields
Target Field
OAS Field
Source Field
Transformation Logic
SA_FACT_KEY
Service Agreement Fact Key
This field is populated with the sequence from B1_SA_SEQ.
SRC_SA_ID
Service Agreement ID (Natural Key)
CI_SA.SA_ID
CURRENCY_CD
Currency Code
CI_SA.CURRENCY_CD
SA_DURATION
Service Agreement Duration
CI_SA.START_DT
CI_SA.END_DT
If the end date is not populated, set SA Duration = 0. Else, set SA Duration (computed in hours) = End Date – Start Date.
FACT_CNT
Count
This field is populated with the standard value of “1”.
ACCT_KEY
CI_SA.ACCT_ID
ADDR_KEY
CI_SA.CHAR_PREM_
ID
START_DATE_KEY
Start Date (Date Dimension Surrogate Key)
CI_SA.START_DT
END_DATE_KEY
End Date (Date Dimension Surrogate Key)
CI_SA.END_DT
PER_KEY
CI_ACCT_PER.PER_
ID
This field is populated with the main person of the account.
PREM_KEY
CI_SA.CHAR_PREM_
ID
SA_KEY
CI_SA.SA_ID
SA_STATUS_KEY
Service Agreement Status Dimension Surrogate Key
CI_SA.SA_STATUS_
FLG
SA_UDD1_KEY
Service Agreement User Defined Dimension 1 Surrogate Key
SA_UDD2_KEY
Service Agreement User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
User Defined Measure 11
UDM12
User Defined Measure 12
UDM13
User Defined Measure 13
UDM14
User Defined Measure 14
UDM15
User Defined Measure 15
UDM16
User Defined Measure 16
UDM17
User Defined Measure 17
UDM18
User Defined Measure 18
UDM19
User Defined Measure 19
UDM20
User Defined Measure 20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
User Defined Degenerate Dimension 6
UDDGEN7
User Defined Degenerate Dimension 7
UDDGEN8
User Defined Degenerate Dimension 8
UDDGEN9
User Defined Degenerate Dimension 9
UDDGEN10
User Defined Degenerate Dimension 10
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDGENL6
User Defined Long Degenerate Dimension 6
UDDGENL7
User Defined Long Degenerate Dimension 7
UDDGENL8
User Defined Long Degenerate Dimension 8
UDDGENL9
User Defined Long Degenerate Dimension 9
UDDGENL10
User Defined Long Degenerate Dimension 10
UDDGEN_NUM1
User Defined Numeric Degenerate Dimension 1
UDDGEN_NUM2
User Defined Numeric Degenerate Dimension 2
UDDGEN_NUM3
User Defined Numeric Degenerate Dimension 3
UDDGEN_NUM4
User Defined Numeric Degenerate Dimension 4
UDDGEN_NUM5
User Defined Numeric Degenerate Dimension 5
UDDGEN_NUM6
User Defined Numeric Degenerate Dimension 6
UDDGEN_NUM7
User Defined Numeric Degenerate Dimension 7
UDDGEN_NUM8
User Defined Numeric Degenerate Dimension 8
UDDGEN_NUM9
User Defined Numeric Degenerate Dimension 9
UDDGEN_NUM10
User Defined Numeric Degenerate Dimension 10
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
UDDFK6_KEY
User Defined Dimension Foreign Key 6
UDDFK7_KEY
User Defined Dimension Foreign Key 7
UDDFK8_KEY
User Defined Dimension Foreign Key 8
UDDFK9_KEY
User Defined Dimension Foreign Key 9
UDDFK10_KEY
User Defined Dimension Foreign Key 10
UD_DATE1
User Defined Date Field 1
UD_DATE2
User Defined Date Field 2
UD_DATE3
User Defined Date Field 3
UD_DATE4
User Defined Date Field 4
UD_DATE5
User Defined Date Field 5
UD_DATE6
User Defined Date Field 6
UD_DATE7
User Defined Date Field 7
UD_DATE8
User Defined Date Field 8
UD_DATE9
User Defined Date Field 9
UD_DATE10
User Defined Date Field 10
UD_DATE1_KEY
User Defined Date Key Field 1
UD_DATE2_KEY
User Defined Date Key Field 2
UD_DATE3_KEY
User Defined Date Key Field 3
UD_DATE4_KEY
User Defined Date Key Field 4
UD_DATE5_KEY
User Defined Date Key Field 5
UD_DATE6_KEY
User Defined Date Key Field 6
UD_DATE7_KEY
User Defined Date Key Field 7
UD_DATE8_KEY
User Defined Date Key Field 8
UD_DATE9_KEY
User Defined Date Key Field 9
UD_DATE10_KEY
User Defined Date Key Field 10
DATA_SOURCE_IND
JOB_NBR
Job Number
Uncollectible Event
Stores all write-off events defined in the source system.
Properties
Property
Value
Target Table Name
CF_UCOL_EVT
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_WO_EVT
Stage Table Name
STG_CF_UCOL_EVT
ODI Package Name
B1_PKG_CF_UCOL_EVT
ETL View Name
B1_F_UCOL_EVT_VW
n/a
Fields
Target Field
OAS Field
Source Field
ACCT_KEY
CI_WO_PROC.ACCT_
ID
ADDR_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
If the mailing premise on the account is not found, then the characteristic premise on the service agreement will be used.
SRC_UCPROC_ID
Uncollectible Process ID (Natural Key)
CI_WO_PROC.WO_
PROC_ID
UCOL_EVT_KEY
Uncollectible Event Fact Key
This field is populated with the sequence from B1_UCOL_EVT_SEQ.
CURRENCY_CD
Currency Code
CI_ACCT.CURRENCY_CD
This field is populated with the currency code from account.
EVT_DATE_KEY
Uncollectible Event Date
CI_WO_EVT.COMPLETION_DT
PER_KEY
CI_ACCT_PER.PER_
ID
This field is populated with the main customer of the account associated with the write-off event.
PREM_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
If the mailing premise on the account is not found then the characteristic premise on the service agreement will be used.
UCEVT_TYPE_KEY
Uncollectible Event Type Dimension Surrogate Key
CI_WO_EVT.WO_EVT_TYP_CD
UCOL_EVT_SEQ
Uncollectible Event Sequence
CI_WO_EVT.EVT_SEQ
UCPROC_TMPL_KEY
Uncollectible Process Template Dimension Surrogate Key
CI_WO_PROC.WO_PROC_TMPL_CD
FACT_CNT
Count
UDM1
UDM2
UDM3
UDDGEN1
UDDGEN2
UDDGEN3
UCEVT_UDD1_KEY
Uncollectible Event User Defined Dimension 1 Surrogate Key
UCEVT_UDD2_KEY
Uncollectible Event User Defined Dimension 2 Surrogate Key
DATA_SOURCE_IND
JOB_NBR
Job Number
Stores all write-off processes defined in the source system. This fact captures metrics, such as the duration of the process, the arrears at the start of the process, and at the end of the process.
Properties
Property
Value
Target Table Name
CF_UCOL_PROC
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_WO_PROC
Stage Table Name
STG_CF_UCOL_PROC
ODI Package Name
B1_PKG_CF_UCOL_PROC
ETL View Name
B1_F_UCOL_PROC_VW
B1_UCOLLPROC_MON_MV1
B1_UCOLLPROC_MON_MV2
B1_UCOLLPROC_MON_TOPX_MV1
B1_UCOLLPROC_MON_TOPX_MV2
Fields
Target Field
OAS Field
Source Field
UCPROC_KEY
Uncollectible Process Fact Key
This field is populated with the sequence from SPL_UCPROC_SEQ.
SRC_UPROC_ID
CI_WO_PROC.WO_PROC_ID
CURRENCY_CD
Currency Code
CI_ACCT.CURRENCY_CD
UCPROC_DURATION
Uncollectible Process Duration
CI_WO_PROC.CRE_DTTM
This field is populated as the difference (in hours) between the creation date of the write-off process and the maximum completion date of the associated write-off events.
ARRS_AT_START
Arrears at Start
CI_FT.TOT_AMT
This field is calculated as the sum of total balance of all the service agreements linked to the write-off process as of the creation date.
ARRS_AT_END
Arrears at End
CI_FT.CUR_AMT
This field is populated only if status of the write-off process is not active. It is calculated as the sum of the current balance of all the service agreements linked to the write-off process as of the max completion date of the associated write-off events.
ARRS_DIFF
This field is populated only if status of the write-off process is not active. It is calculated as the difference between the arrears at start and arrears at end.
FACT_CNT
Fact Count
ACCT_KEY
CI_WO_PROC.ACCT_
ID
ADDR_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
If the mailing premise on the account is not found, the characteristic premise on the service agreement will be used.
PER_KEY
CI_ACCT_PER.PER_
ID
This field is populated with the main customer of the account associated with the write-off process.
PREM_KEY
CI_ACCT.MAILING_
PREM_ID
CI_SA.CHAR_PREM_
ID
START_DATE_KEY
CI_WO_PROC.CRE_
DTTM
END_DATE_KEY
Uncollectible Process End Date
CI_WO_PROC.CRE_
DTTM
The field is populated only when the write-off process is not active. It is populated with the maximum write-off event completion date. If no event completion dates are found, creation date of the write-off process will be used.
UCPROC_STAT_KEY
Uncollectible Process Status Dimension Surrogate Key
CI_WO_PROC.WO_STATUS_FLG
Note that the write-off process statuses from the source will be transformed while storing in the fact.
• If the write-off process is ‘Active’, the same status will be retained.
• If the write-off process is ‘Inactive’ and status reason is ‘Completed’, then the status will be marked as ‘Ineffective’ in the fact.
• Otherwise the status will be marked as ‘Effective’ in the fact.
UCPROC_TMPL_KEY
UCPROC_UDD1_KEY
Uncollectible Process User Defined Dimension 1 Surrogate Key
UCPROC_UDD2_KEY
Uncollectible Process User Defined Dimension 2 Surrogate Key
UDDGEN1
UDDGEN2
UDDGEN3
UDM1
UDM2
UDM3
DATA_SOURCE_IND
JOB_NBR
Job Number
Recent To Do Entry
The Recent To Do Entry fact stores all To-Do entries that have been completed in the last ‘X’ days and also the incomplete To-Do entries.
The value ‘X’ has to be configured as part of the BI configuration in the source system. For details, see the BI-Oriented Master Configuration in the Oracle Utilities Customer Care & Billing (CCB) section (in the Configuring Oracle Utilities Analytics Warehouse chapter) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide.
Properties
Property
Value
Target Table Name
CF_RECENT_TD_ENTRY
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_TD_ENTRY
Stage Table Name
STG_CF_RECENT_TD_ENTRY
ODI Package Name
B1_PKG_CF_RECENT_TD_ENTRY
ETL View Name
B1_F_TD_ENTRY_VW
n/a
Fields
Target Field
OAS Field
Source Field
TD_ENTRY_KEY
To Do Dimension Surrogate Key
This field is populated with the sequence from OUBI_TD_ENTRY_SEQ.
SRC_TD_ENTRY_ID
To Do Entry ID (Natural Key)
CI_TD_ENTRY.TD_ENTRY_ID
SA_KEY
CI_TD_ENTRY_CHA.CHAR_VAL_FK1
This field is populated with the SA ID associated with the To Do Entry for characteristic type configured as part of the BI configuration in the source system.
PER_KEY
This field is populated with the Person ID associated with the To Do Entry for characteristic type configured as part of the BI configuration in the source system.
ACCT_KEY
This field is populated with the Account ID associated with the To Do Entry for characteristic type configured as part of the BI configuration in the source system.
PREM_KEY
This field is populated with the Premise ID associated with the To Do Entry for characteristic type configured as part of the BI configuration in the source system.
ADDR_KEY
USER_KEY
User Dimension Surrogate Key
CI_TD_ENTRY.ASSIGNED_USER_ID
TD_TYPE_KEY
To Do Type Dimension Key
CI_TD_ENTRY.TD_TYPE_CD
TD_ROLE_KEY
To Do Role Dimension Key
CI_TD_ENTRY.ROLE_ID
TD_STATUS_KEY
To Do Status Dimension Key
CI_TD_ENTRY.ENTRY_STATUS_FLG
TD_PRIORITY_KEY
To Do Priority Dimension Key
CI_TD_ENTRY.TD_PRIORITY_FLG
TD_SKILL_KEY
To Do Skill Dimension Surrogate Key
CI_TD_TYPE_CHAR.ADHOC_CHAR_VAL
CI_TD_TYPE_CHAR.CHAR_TYPE_CD
CI_TD_TYPE_CHAR.CHAR_VAL
This field is populated based on the characteristic types configured on the To Do entry’s To Do type. Only those characteristic types configured as skills in the AQM feature configuration will be considered.
If a To Do type has both regular skills and ad-hoc skills, then the ad-hoc skills will be given the priority. The first skill to match the message category/number on the To Do entry will be picked up.
MSG_KEY
CI_TD_ENTRY.MESSAGE_CAT_NBR
CI_TD_ENTRY.MESSAGE_NBR
TD_KEY
CREATE_DATE_KEY
Create Date (Date Dimension Surrogate Key)
CI_TD_ENTRY.CRE_DTTM
This field is populated with the date portion.
CREATE_TIME_KEY
Create Time (Time Dimension Surrogate Key)
This field is populated with the time portion.
CREATE_DTTM
Create Date/Time
CMPL_DATE_KEY
Complete Date (Date Dimension Surrogate Key)
CI_TD_ENTRY.COMPLETE_DTTM
CMPL_TIME_KEY
Complete Time (Time Dimension Surrogate Key)
CMPL_DTTM
Complete Date/Time
ASSIGN_DATE_KEY
Assign Date (Date Dimension Surrogate Key)
CI_TD_ENTRY.ASSIGNED_DTTM
ASSIGN_TIME_KEY
Assign Time (Time Dimension Surrogate Key)
ASSIGN_DTTM
Assign Date/Time
This field is populated with the last assigned date/time of the respective To-Do entry.
OPEN_IND
Open Indicator
This field is populated with “1” if the To Do entry is still ‘Open’. Else, it is populated with “0”.
ASSIGN_IND
Assigned Indicator
This field is populated with “1” if To Do entry is still ‘Assigned’. Else, it is populated with “0”.
CMPL_IND
Completed Indicator
This field is populated with “1” if To Do entry is still ‘Completed’. Else, it is populated with “0”.
REL_TODOS_CNT
Number of Related To Dos
This field is populated with the count of other incomplete To Do entries that reference the same set of characteristics as the current To Do entry.
HOURS
Hours
CI_TD_ENTRY.CRE_
DTTM
This field is populated with the number of hours between the Create Time and Completion Time. It is populated with “0” if the respective To Do is incomplete.
OPEN_HOURS
Open Hours
CI_TD_LOG.LOG_
DTTM
This field is populated with the total number of hours the To Do entry was in “Open” state (not assigned).
ASSIGN_HOURS
Assign Hours
CI_TD_LOG.LOG_
DTTM
This field is populated with the total number of hours the To Do entry was in “Being Worked On” state. It is populated with “0” if the respective To Do is still being worked on. It is populated with “0” if the respective To Do is still Open.
UDM1
UDM2
UDM3
UDM4
UDM5
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
FACT_CNT
Fact Count
DATA_SOURCE_IND
CI_INSTALLATION.
ENV_ID
JOB_NBR
Job Number
To Do Entry
Accumulates all To-Do entries created in the source system. This fact captures metrics, such as the number hours it was open, assigned, total hours, and also the number of related To Dos.
Properties
Property
Value
Target Table Name
CF_TD_ENTRY
Table Type
Fact
Fact Type
Accumulation
Driver Table
CI_TD_ENTRY
Stage Table Name
STG_CF_TD_ENTRY
ODI Package Name
B1_PKG_CF_TD_ENTRY
ETL View Name
B1_F_TD_ENTRY_VW
B1_TD_ENTRY_DOW_MV1
B1_TD_ENTRY_DOW_MV2
B1_TD_ENTRY_MON_TOPX_MV1
Fields
Target Field
OAS Field
Source Field
TD_ENTRY_KEY
SRC_TD_ENTRY_ID
CI_TD_ENTRY.TD_
ENTRY_ID
SA_KEY
PER_KEY
ACCT_KEY
PREM_KEY
ADDR_KEY
USER_KEY
TD_TYPE_KEY
TD_ROLE_KEY
CI_TD_ENTRY.ROLE_ID
TD_STATUS_KEY
TD_PRIORITY_KEY
TD_SKILL_KEY
MSG_KEY
TD_KEY
CI_TD_ENTRY.TD_
ENTRY_ID
CREATE_DATE_KEY
CI_TD_ENTRY.CRE_
DTTM
CREATE_TIME_KEY
CI_TD_ENTRY.CRE_
DTTM
CREATE_DTTM
Create Date/Time
CI_TD_ENTRY.CRE_
DTTM
CMPL_DATE_KEY
CMPL_TIME_KEY
CMPL_DTTM
Complete Date/Time
ASSIGN_DATE_KEY
ASSIGN_TIME_KEY
ASSIGN_DTTM
Assign Date/Time
OPEN_IND
Open Indicator
ASSIGN_IND
Assigned Indicator
CMPL_IND
Completed Indicator
REL_TODOS_CNT
HOURS
Hours
CI_TD_ENTRY.CRE_
DTTM
OPEN_HOURS
Open Hours
CI_TD_LOG.LOG_
DTTM
ASSIGN_HOURS
Assign Hours
CI_TD_LOG.LOG_
DTTM
UDM1
UDM2
UDM3
UDM4
UDM5
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGEN6
UDDGEN7
UDDGEN8
UDDGEN9
UDDGEN10
TD_ENTRY_UDD1_KEY
To Do Entry User Defined Dimension 1 Surrogate Key
TD_ENTRY_UDD2_KEY
To Do Entry User Defined Dimension 2 Surrogate Key
TD_ENTRY_UDD3_KEY
To Do Entry User Defined Dimension 3 Surrogate Key
TD_ENTRY_UDD4_KEY
To Do Entry User Defined Dimension 4 Surrogate Key
TD_ENTRY_UDD5_KEY
To Do Entry User Defined Dimension 5 Surrogate Key
FACT_CNT
Fact Count
DATA_SOURCE_IND
JOB_NBR
Job Number
