Object Naming Convention
All out-of-the-box objects are prefixed with ‘B1’ and should not be modified. It is recommended to choose a two-character code to prefix the custom objects to avoid any naming conflicts between the product components and the custom components.
Use ‘CM’ as a prefix for all objects that you create (CM references to Customer Modification).
