Multi-Service Forecast
The Multi-Service Forecast module is included in the Email High Bill Alert AMI for business customers who have both gas and electric service.
Example
This image shows an example of the Electric Gas Comparison module:
This image shows an example of the image.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Options Input Value
Heading
You can update the heading of the module.
Default: "Electric and gas breakdown".
Optional
Choose one of the following:
  • Use the "Electric and gas breakdown" heading. (Default)
  • Use the following heading:
Subheading
You can configure the subheading in the module as necessary.
Default: "You're projected to spend <more/less> on <fuel/resource> than the same time last year."
For example, "You're projected to spend more on electricity and gas than the same time last year."
Optional
  • Use the default subheading.
Bar Chart Labels
The labels below the bars in the chart can be updated.
Defaults:
  • Electricity
  • Gas
Optional
  • Use the default labels.
  • Use the following labels:
Decimal Places
You can configure the module to display up to two decimal places for the amounts above the bars.
Default: Display zero decimal places.
Optional
  • Display zero decimal places. (Default)
  • Display this many decimal places:
Legend Labels
The legend labels below the chart can be updated.
Defaults:
  • Projected bill
  • Same time last year
Optional
User Experience Variations
This section describes the user experience variations in the Electric and Gas Comparison module.
Usage
If the customer receives a usage version of the email, this module shows usage instead of costs. Electricity is displayed in kWh, and gas is displayed in therms.
Subheading
The subheader changes based on whether a customer spends more or less than they did during the same period last year. The customer most have spent at least 10% more than the previous year to be considered "spending more" during the current bill period. This 10% threshold for the comparison states is not configurable. These subheader variations are possible:
  • Customers spends 10% more on both fuel types: "You're projected to spend more on electricity and gas than the same time last year."
  • Customer spends 10% more on one fuel type, but not the other: "You're projected to spend more on <fuel type> than the same time last year."
  • Customer spends less: "You're projected to spend less on electricity and gas than the same time last year." Note that this occurs only when the customer's bill forecast exceeds their personal cost threshold, even though they did not spend more.
  • Customer spends about the same: "You're projected to spend about the same on electricity and gas than the same time last year." Note that this occurs only when the customer's bill forecast exceeds their personal cost threshold, even though they did not spend more.
