Data Browser
The Data Browser is an interactive tool that allows business customers to visualize and explore their energy use trends and costs, and make comparisons to useful benchmarks such as local weather patterns. One or more views for Energy Costs, Energy Use, and Power are available. If applicable, business customers can also use menus to switch between multiple accounts or service points.
Use the information below to review general configuration options for the Data Browser, such as which views to enable, the order of the views, and the default time view. For configurations that are specific to each view, see Energy Use View, Energy Costs View, or Power View.
General Configuration Options
Use the information below to review general configuration options for the Data Browser. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Graph Display and Order Utilities can choose which graphs to display and the order in which to display them. Default: The following graphs are displayed in the order listed as long as there is sufficient data: Energy Costs, Energy Use, and Power. |
Required Choose one of the following:
Tooltip Explanation Link for Estimated Reads (not depicted) Utilities can provide a URL to include as an explanation link for estimated reads. Default: No link provided. |
Optional Choose one of the following:
Default Fuel or Resource Type Selected Utilities can choose which fuel or resource type to be selected by default. Default: Display electric data as default. |
Combined Fuel View For dual fuel customers with electricity and gas service, a combined fuel view combines the energy use for gas and electricity into a single "units" value. When combined fuel view is enabled, applicable tooltips also display combined totals. Combined view also includes billing insights for a customer's energy costs. Default: Hide the combined fuel view. |
Default Time View The Bill view can be displayed by default for customers with AMI data. Customers without AMI data can only use the Year view. Default: Display the Year view as the initial view. Customers with AMI data can then select to see the Bill view or Day view. |
Display of Device (Meter) ID in Drop-Down Selector The device ID (meter number) can be displayed instead of the service point ID in the drop-down selector menu of relevant widgets. Displaying the device ID can be a clearer way for customers to identify the energy use patterns associated with each of their meters. Default: Disabled. |
Display of Custom Meter or Service Point Names The ability to add custom names to meters or service points in the widget can be enabled. This lets customers define custom names for each meter or service point so they can more easily distinguish and select the appropriate one when viewing data in the widget.
Note: Your Oracle Utilities Delivery Team must complete additional setup before this option can be enabled.Default: Disabled. |
Display of Disclaimers by Customer Type (Residential or Non-Residential) The widget can be configured to show customer type-specific disclaimer text (for residential or non-residential customers) in each of its views. This helps utilities present more relevant explanatory information without needing to maintain separate widget instances. A general disclaimer can remain available as a fallback when a customer-specific message is not configured.Default: No disclaimer, or a generic disclaimer if one has been configured. |
User Experience Variations
The user experience of the feature may vary for customers and utilities depending upon their service types (gas, electricity, dual fuel, and so on), available data, costs, locale, and other factors. For more information, see Data Browser in the Business Customer Engagement Digital Self Service - Energy Management Overview Guide.
