Activating and Testing the Integration Flows
This section provides an overview of how integration flows are activated and tested. It includes the following sections:
Prerequisites
Make sure the catalog in Oracle Utilities Customer Cloud Service is configured completely to activate an integration process.
Activating Integration Flows
To activate the integration flows:
  1. Navigate to the integration to activate.
  2. Drag the slider for that integration. When prompted to enable tracing, click Yes to view the instances.
  3. Click Activate.
The integration takes time to get activated. The activated integration appears at the top of the integrations list.
The following table lists the end point URLs for respective applications in which these endpoints need to be configured. Configure the same and perform an end-to-end testing.
Integration NameEnd Point URL to be ConfiguredApplication to be Configured
OUCCS CX Person Synchttps://hostname:port /ic/ws/integration/v2/flows/oracleutilities/project/OUTL-BA-CCS_CX/OUTL-BA-CCS_CX_PERSON_SYNC/1.0/personSyncCCS
OUCCS CX Case Synchttps://hostname:port /ic/ws/integration/v2/ flows/oracleutilities/project/OUTL-BA-CCS_CX/OUTL-BA-CCS_CX_CASE_SYNC/1.0/caseSyncCCS
