Importing, Configuring, and Testing Integration Connections
This chapter explains the process of importing an Oracle Accelerator Project, which imports the connections, integrations, lookups, and libraries, into an Oracle Integration Cloud instance. It also explains the configuration of the imported connections, agents, and security certificates. It includes following sections:
Importing an Oracle Accelerator Project from Oracle Integration Store
To import an Oracle accelerator project from Oracle Integration Store:
  1. Navigate to the Oracle Integration Cloud Home page.
  2. Click Browse Store.
  3. In the store, search for any (or combination) of the following keywords:
    • UGBU
    • CCS
    • Customer Cloud Service
    • CX
    • Oracle Fusion Service
    • OIC
    • Oracle Integration Cloud Service
  4. Select the correct version of “Utilities Customer Cloud Service & CX Fusion Service” from the search results and click Get.
  5. Verify that the new project appears in the project list with the status “Configured”, indicating that the connections have not yet been fully completed.
  6. Click Project Edit and complete the required verification and configuration steps. For detailed instructions, refer to the Verifying the Project Import and Configuring Connections in Oracle Integration Cloud. Then, click Next. My Oracle Support portal opens.
  7. After the configuration is complete, activate the integration either by:
    • Clicking Activate in the Design page of the project.
    • Or, activating the latest deployment plan in the Deploy page of the project.
To verify that the OU CCS CX project import was successful:
  1. Verify that the following integrations are imported successfully as displayed in the Integrations section of the project:
    • OU CCS CX Person Sync
    • OU CCS CX Case Sync
    • OU Common Notification Handler
    • OU CX CCS Contact Account Sync
    • OU CX Account Update Event
    • OU CX Account Delete Event
    • OU CX Contact Update Event
    • OU CX Contact Delete Event
    Note: The version of the integration flows will be 01.26.1000.
  2. Verify that the following connections are imported successfully as displayed in the Connections section of the project:
    • OU REST OIC for CCS-CX
    • OU CX for CCS-CX
    • OU REST CCS for CCS-CX
  3. Verify that the following lookups are imported successfully as displayed in the Lookups section of the project:
    • OUTL-BRT-CCS_CX_CaseCharacteristicType.dvm
    • OUTL-BRT-CCS_CX_CharacteristicValue.dvm
    • OUTL-BRT-CCS_CX_ContactTypeEmailPurpose.dvm
    • OUTL-BRT-CCS_CX_CaseStatus.dvm
    • OUTL-BRT-CCS_CX_BusinessConfigProps.dvm
    • OUTL-BRT-CCS_CX_TechnicalConfigProps.dvm
    • OUTL-BRT-CCS_CX_CaseType.dvm
    • OUTL-BRT-CCS_CX_CaseCondition.dvm
    • OUTL-BRT-CCS_CX_CommunicationType.dvm
    • OUTL-BRT-CCS_CX_ContactTypePhonePurpose.dvm
    • OUTL-BRT-CCS_CX_ContactTypeWebPurpose.dvm
    • OUTL-BRT-CCS_CX_PersonCharacteristicType.dvm
After the project is imported and verified, respective connections must be configured. This section describes the procedure to set up the following connections:
Configuring OU REST OIC for CCS-CX Connection
This connection is used to invoke OIC Lookup REST APIs and also to access the other integration processes using the Oracle REST adapter.
To configure the OU REST OIC for CCS-CX connection:
  1. Select the REST API Base URL from the Connection Type drop-down list
  2. Add the OIC URL in the Connection URL section.
    Example: https://{OIC-Instance}:{OIC-Host}
  3. From the Security Policy drop-down list, select OAuth Client Credentials.
  4. Configure the Access Token URI, Client ID, and Client Secret fields respectively from the OIC instance.
  5. In the Optional Security field, configure the following:
    a. Scope
    b. Client Authentication as “Send client credentials as basic auth header”
  6. On the Connection page, click Test.
  7. After the connection is tested successfully, click Save
This connection is used by the following integrations:
Configuring OU CX for CCS-CX Connection
This connection is used to communicate with Oracle CX Fusion Service using the Oracle CX Sales and B2B Service adapter.
To configure OU CX for CCS-CX connection:
  1. On the connection page, enter the Fusion CX URL in the CX Sales and B2B Service Host field.
    Example: https://<fusion-host>
  2. In the Security section, select the appropriate security policy and configure its required fields. For supported policies and configuration instructions, see Create a Connection in the Oracle Cloud Using the Oracle CX Sales and B2B Service Adapter with Oracle Integration 3 documentation.
  3. In the Access type section, select Public gateway or Private endpoint, depending on your deployment.
  4. Click Test to validate the connection.
  5. After the connection test succeeds, click Save.
Configuring OU REST CCS for CCS-CX Connection
This connection is used to communicate with Oracle Utilities Customer Cloud Service using the Oracle Utilities adapter.
Configure the OU REST CCS for CCS-CX connection with the required details:
  1. Add the Oracle Utilities Customer Cloud Service catalog to the catalogURL section.
    Note: For the on-premises application, the catalog format is:
    http(s)://<CCS_HOST>:<CCS_PORT>/<ContextRoot>/rest/ouaf/openapi/iws/catalog
    For Oracle Utilities Customer Cloud Service, the catalog format is:
    https://{host}:{port}/{tenant}/{domain}/{appName}/rest/openapi/iws/catalog
  2. On the Security policy tab, select the applicable security policy to access the application.
Refer to the Oracle Utilities Adapter documentation for more information on the supported security policies at: https://docs.oracle.com/en/cloud/paas/application- integration/utilities-adapters/understand-oracle-utilities-adapter.html
  1. Click Test to validate the connection.
  2. After the connection is tested successfully, click Save.
