Monitoring and Troubleshooting
This section provides information about monitoring and troubleshooting the integration. It includes the following:
Oracle Utilities Customer Cloud Service
This section provides information about monitoring Oracle Utilities Customer Cloud Service.
Oracle Utilities Customer Cloud Service Error Logs
Monitoring the error logs is possible only in on-premises applications. Applications on cloud cannot access the error logs.
The following error logs can be monitored for Oracle Utilities Customer Cloud Service:
- Errors related to the online integration invocation from Oracle Utilities Customer Cloud Service are stored in the
CCS_ENVIRONMENT_NAME/logs/folder.
Oracle Integration Cloud
This section focuses on the monitoring Oracle Integration Cloud and troubleshooting any issues that occur during the integration activation.
Monitoring Integration Flows
Integration flows are monitored using the following:
Project (for project based instances)
Observability (for non project based instances)
To monitor the integration flows from the Oracle Integration Cloud dashboard:
Login to Oracle Integration Cloud.
Click Projects. On the navigation pane, click the relevant project.
Navigate to the Observe menu.
You can check:
a. Integrations to view the counts of various status of instances created per integration flows.
b. Instances to see instances of integrations of the project.
c. Future runs to see all the runs scheduled or started for scheduled integrations.
d. Audit to view and download design-time audit logs.
For more information, refer to the Monitor Integrations in a Project section in Using Integrations in Oracle Integration 3 at https://docs.oracle.com/en/cloud/paas/application-integration/integrations-user/monitor-integrations-project.html.
To monitor integration flows outside the project using Oracle Integration Cloud Observability menu option:
Click Observability on the menu.
Select any of the following as required:
Dashboards: To monitor the complete dashboard of integration.
Integrations: To monitor each integration.
Instances: To monitor instance and flow trace/activity stream of the integration.
- Error: To monitor the integrations in ‘error’ state. Re-submit the asynchronous integration flows.
Troubleshooting
If an activation fails, the Integrations page displays an error message. To troubleshoot the activation error:
Click Download Diagnostic Logs to download the logs for diagnosing the issue.
Select Enable Tracing.
TRACE ENABLED is displayed next to ACTIVE.
Some of the sample cases are as follows:
For any connectivity errors while activating the integration, make sure the trigger connection is successful. Test the connection and refresh the metadata, and then activate the integration.
If the integration (Oracle Utilities Customer Cloud Service initiated flows) is activated for the first time, ensure the Oracle Utilities Customer Cloud Service catalog is configured accurately
