Migrating from OIC Test Environment to Production
Make sure all Oracle Integration Cloud artifacts are imported successfully.
To import the customizations added in the test environment to production:
1. Export the ccs_offs_fieldwork_custom_26.10 project from the test environment and import it into the production environment.
2. Configure all your connections in the Connections section of the Accelerator project.
3. Activate the base integrations and customized integrations, and configure the respective end point URL into the Oracle Utilities Customer Cloud Service Message Sender and OFFS plugin as applicable.
4. Deactivate the base integrations for which a cloned, customized integration copies were created.
