Importing and Verifying the Integration Project
Importing Oracle Accelerator Project from Oracle Integration Store
To import an Oracle Accelerator Project from Oracle Integration Store:
  1. Navigate to the Oracle Integration Cloud Home page.
  2. Click Browse Store.
  3. In the store, search for any (or combination) of the following keywords:
    • UGBU
    • CCS
    • OPOWER
    • Customer Cloud Service
  4. Select the correct version of “Oracle Utilities Customer Cloud Service to Opower” from the search results and click Get.
  5. Verify that the new project appears in the project list with the status “Configured”, indicating that the connections have not yet been fully completed.
  6. Click Project Edit and complete the required verification and configuration steps. For detailed instructions, refer to Verifying the Project Import and Configuring Connections in Oracle Integration Cloud documentation. Then, click Next. The My Oracle Support portal opens.
  7. After the configuration is complete, activate the integration either by:
    • Clicking Activate in the Design page of the project.
    • Or, activate the latest deployment plan in the Deploy page of the project.
Note: All integration flows are shipped as part of a single accelerator project (.car) file.
To verify the project was imported successfully, go to the OU CCS OPOWER project:
  1. In the Integrations section of the project, verify that the following integrations were imported successfully:
    • OU OPOWER CCS Affordability File Transfer (1.26.1000)
    • OU OPOWER CCS Sent Customer Communication Sync (1.26.1000)
    • OU OPOWER CCS Push Customer Communication Sync (1.26.1000)
    • OU CCS OPOWER Account Communications Get (1.26.1000)
    • OU CCS OPOWER Communication Content Get (1.26.1000)
    • OU Common Configuration Properties Lookup Update (1.26.1000)
    • OU CCS Common FTP Transfer (1.26.1000)
    • OU CCS Common OS Transfer (1.26.1000)
    • OU Common Notification Handler (1.26.1000)
  2. In the Connections section of the project, verify that the following connections are imported successfully:
    • OU REST OPOWER for CCS-OPOWER
    • OU REST CCS for CCS-OPOWER
    • OU REST INVK OIC for CCS-OPOWER
    • OU REST OPOWER Object Storage for CCS-OPOWER
    • OU REST CCS Object Storage for CCS-OPOWER
    • OU REST TRIG for CCS-OPOWER
    • OU FTP CCS for CCS-OPOWER
  3. In the Lookups section of the project, make sure that the following lookups are imported successfully:
    • OUTL-BRT-CCS_OPWR_BusinessConfigProps
    • OUTL-BRT-CCS_OPWR_TechnicalConfigProps
    • OUTL-BRT-CCS_OPWR_CommunicationStatus
    • OUTL-BRT-CCS_OPWR_DeliveryChannel
