Integration Overview
This guide describes the integration between Oracle Utilities Customer Cloud Service and Oracle Utilities Opower using Oracle Integration Cloud, including participating applications, requirements, prerequisites, and supported business processes.
Overview of the Integration
The integration between Oracle Utilities Customer Cloud Service integration and Oracle Utilities Opower passes details of customer communication and affordability insights from Opower to Customer Cloud Service.
Details of Opower email and push communications are sent to Customer Cloud Service, where each communication is recorded as a customer contact. The integration can also pass a link to the communication’s content, allowing Customer Cloud Service users to view it from the associated customer contact record.
Affordability indicators are passed from Opower to Customer Cloud Service. This enables Customer Cloud Service to display affordability insights.
About Oracle Utilities Customer Cloud Service (CCS)
Oracle Utilities Customer Cloud Service is a customer care, service order, metering, and billing solution for traditional scalar devices and billing processes. The solution is designed to cater for utilities of all sizes, supports one to many utility service types, and handles the complexities associated with a utility’s processes.
Oracle Utilities Customer Cloud Service includes:
About Oracle Utilities Opower
Oracle Utilities Opower helps utilities deliver personalized energy insights that empower residential and business customers to understand their energy use, manage costs, and take action to save. Its cloud services combine energy data, analytics, AI, and behavioral science to support energy efficiency and customer engagement.
With Opower, utilities can provide:
About Oracle Integration Cloud (OIC)
Oracle Integration Cloud is a cloud-based integration application designed to integrate cloud and on-premises applications, automate business processes, gain insight into your business processes, develop visual applications, process files, and exchange business documents with a business-to-business (B2B) partner.
With the Process Builder business processes can be rapidly designed, automated, and managed in the cloud. Continuous business flows are quickly created by connecting and integrating applications that live in the cloud and/or on-premises.
Domain Value Map or lookups are available to match application specific codes between the applications.
Integration Insights and Stream Analytics help to simplify and extract business metrics and create custom dashboards.
Software Requirements
The following software is required for the integration to work:
For specific application versions, refer to the Oracle Utilities Customer Cloud Service Integration to Oracle Utilities Opower Release Notes included in this release. The documentation is available on the Oracle Utilities Integrations page on Oracle Help Center.
Prerequisites
Make sure all participating applications are installed, set up, and working properly.
Supported Business Processes
The following diagram illustrates the supported business processes of this integration:
CCS and Opower exchange affordability files and customer communications through OIC. CCS also requests account communications and communication content links.
The integration supports:
