Monitoring, Troubleshooting, and Limitations
Oracle Utilities Customer Cloud Service
This section provides information about monitoring Oracle Utilities Customer Cloud Service logs.
See the Troubleshooting section in the Oracle Utilities Cloud Services Implementation Guide on Oracle Help Center for more information.
Cloud Service Logs
The customer or system integrator can request access logs from cloud environments. Every Access Log request will require a service request to be logged in My Oracle Support.
On-Premises Application Logs
Application related error logs can be viewed from:
For more information, refer to the Oracle Utilities Customer Cloud Service documentation on Oracle Help Center.
Oracle Integration Cloud
This section focuses on the monitoring of the Oracle Integration Cloud, as well as on the troubleshooting of issues related to the integration activation:
Monitoring Integration Flows
Integration flows are monitored from:
To monitor the integration flows within a project:
  1. Login to Oracle Integration Cloud.
  2. Click Projects. On the navigation pane, click the relevant project.
  3. Navigate to the Observe menu, where you can consult the following:
    • Integrations: To view the counts of various status of instances created per integration flows.
    • Instances: To see instances of integrations of the project.
    • Future runs: To see all the runs scheduled or started for scheduled integrations.
    • Audit: To view and download design-time audit logs.
To monitor the integration flows through the Oracle Integration Cloud menu:
  2. On the navigation pane, click Observability.
  3. Select the following as required:
    • Dashboards: To monitor the complete integration information. Get at-a-glance information about the number and status of your projects, integrations, connections and more.
    • Integrations: The Monitor integrations page lets you view the message processing status of your running integrations. It shows how many messages have been received and processed and how many messages are successful, in error or terminated and errors have occurred, and how many messages have been terminated. To monitor each integration.
    • Instances: To filter and track the status of integration instances and show the flow trace/activity stream of the integration.
    • Error: To manage errors in Oracle Integrations. Resubmit failed instances, discard failed instances, view message recovery status, and view basic and detailed error messages.
For more information, refer to Explore the Navigation Pane.
Troubleshooting
To troubleshoot the errors in the workflow through the generated instances, you can set tracing level to DEBUG to generate detailed logs.
To enable DEBUG:
  1. Select Configure Activation and then select the Tracing Level to be ‘DEBUG’.
  2. Run the integration and check the activity stream which now will include the runtime log details of the flow.
  3. If an activation fails, the Integrations page displays an error message. Some of the sample cases are as follows:
    • For any connectivity errors while activating the integration, make sure the trigger connection is successful. Test the connection and refresh the metadata, and then activate the integration.
    • For Oracle Utilities Customer Cloud Service initiated integration flows activated for the first time, make sure that Oracle Utilities Customer Cloud Service catalog is configured accurately. All external systems and inbound web services used by the integration are defined in the catalog.
Limitations and Workarounds
See Limitations and Workarounds for release-specific limitations and release notes.
