Multiple Portal Servers
Starting with release 26.4, dynamic connection support enables communication with multiple ESRI ArcGIS portal servers for the following integration flows:
OU ArcGIS WACS Initial Assets Sync
OU ArcGIS WACS Incremental Assets Sync
OU WACS ArcGIS Asset Update. Previously, these flows were limited to three predefined servers and required cloning the project to support additional connections.
With this enhancement, assets can be distributed across multiple ArcGIS portals. The ServerId can be defined per AssetClass in OUTL-BRT-ArcGIS_WACS_AssetClass and mapped to a corresponding connectionId in OUTL-BRT-ArcGIS_WACS_ESRI_Connections. At runtime, OIC resolves and uses the appropriate connection based on this mapping. If the ServerId for a given AssetClass is left blank, the default connection is used.
